Possible VTEC problem. Not Really sure.
Old Jan 7, 2009 | 08:39 PM
gonnatell1's Avatar
Default Possible VTEC problem. Not Really sure.
Hey, im new here and i have a problem with my car. I dont know much about Hondas so im hoping to get some help. Its a 1998 4dr Accord with a 2.3 Liter VTec SOHC automatic trans. Just 2 days ago i changed out both gaskets on the Vtec solenoid because they were both leaking oil. I got the gasket that sits between the head and solenoid at the dealer but they told me the smaller one on the spool valve is not produced anywhere. So instead, i used black rtv to seal it. I applied the rtv and let it sit for about a day. I put the solenoid back on and changed my oil with a new filter and put in the correct amount of oil. I drove it all day but it acts funny when i push it just a bit hard. It starts hesitating or it seems like its bouncing off a rev limiter at about 4000 RPM. I posted the video on youtube so yall can see. The link is below.
http://www.youtube.com/watch?v=TTX22XXUDss
Oh yeah, its an all stock motor and the check engine light is due to a egr valve.
Old Jan 8, 2009 | 09:01 AM
AFAccord's Avatar
Default Re: Possible VTEC problem. Not Really sure.
Rev limiter @ 4,000 indicates limp mode because the VTEC solenoid is not working correctly. Sounds like your RTV squeezed into the solenoid ports when you tightened it down, clogging it up. I don't recall any parts in that area requiring a silicone sealant. Pull the solenoid off and scrape that silicone out if you still can.
Old Jan 10, 2009 | 07:41 PM
tpot90's Avatar
x2
Old Jan 10, 2009 | 07:47 PM
dleccord's Avatar
I bet you forgot to use the gasket sealant.
Old Jan 10, 2009 | 11:18 PM
gonnatell1's Avatar
I replaced the first gasket shown but the smaller one on the right is not produced. But that makes sense about the rtv messing up the plunger on the solenoid. Ima scrape that off and try to find that gasket somewhere else.
Old Jan 11, 2009 | 11:10 AM
hondafab19's Avatar
they make that gasket for sure , you can maybe
check out your local parts dealer ..they should have it.
Old Jan 11, 2009 | 09:38 PM
gonnatell1's Avatar
Yeah, i thought so. But the guy at the dealer said they dont produce it at all. But i could tell he was trying to hustle me into buying the whole solenoid because his only solution to fixing the oil leak was buying the solenoid. Ima try another honda dealership in town tomorrow.
Old Jan 17, 2009 | 05:26 PM
silveraccord2000's Avatar
Icon2 Re: Possible VTEC problem. Not Really sure.
im having the same problem wit my 2000 accord that revs up to 4000rpms but then it shoots to 6000rpms. could it b the same problem?
carracr625
Jun 16, 2017 06:34 PM
blkcivic310
10
Feb 3, 2010 11:47 AM
honda gsr01
May 19, 2008 08:53 PM
DC2_ITR
Apr 27, 2007 12:55 PM
DIYMIKE
May 30, 2004 11:46 AM
