need help with clutch/ tranny prob please need help asap
Old Jan 7, 2009 | 02:19 PM
dominicanboi215's Avatar
Default need help with clutch/ tranny prob please need help asap
oh i hav a 98 integra with a h22 swap and to start off i have shifting problems it cant be tranny problem because the gears dont grind wen i change into every gear it feels as in im shifting with no clutch for u's who tired it might noe wat i mean the car shifts wen it wants to also i can hav my foot on the clutch right on the floor the car still moves forward almost as the clutch was engaging... and also hav rpm problems when i turn on the car the rpm's drop then raise in a repeated motion any help to any of ma two questions would be a very big help thanks
Old Jan 7, 2009 | 02:26 PM
preludefury's Avatar
Default Re: need help with clutch/ tranny prob please need help asap
imo from past experiences, with the clutch problem when shifting, its def. ur clutch going. I had the same problem, and its mostly likely a broken spring in the clutch itself.
to your second question, with the RPM's going up and down, it could be one of two things that i know of. One is there could be a Vaccum leak somewhere, and the other possibility is that it could be the IAC valve. which is the Idle Air Control valve, which is located on the throttle body.
I hope this helps, GL man
Old Jan 7, 2009 | 03:27 PM
Kronn 98SH's Avatar
1. Yo clutch be bad, G.
2. Yo FITV (Fast Idle Thermo Valve) be da issue, dogg.
But dat just be ma 2 cent, yall.
GoKOOLjeff
Nov 5, 2006 09:01 PM
Mr_Moos
Dec 12, 2005 08:23 PM
taytay333
Nov 21, 2001 12:58 PM
