Transmission hell!!!
Old Jan 6, 2009 | 08:32 PM
anthrax718's Avatar
Default Transmission hell!!!
i have a 1990 honda civic dx 4 door... my tranny is extremely shitty.. bearings bad syncros worn.. everything you can imagine... so i go to the junkyard and look for a new tranny... alll the 4 dr civics either looked like they been raced or the car had alot of miles.. however i found a 1990 civic hatch with 94k on it so i took the tranny.. i cleaned it up replaced the seals and spun the shaft to make sure it wasnt making any unusual noise.. so when i was puttin the tranny in the splines just wouldnt align for some reason i was there for an hour trying to figure out how to get the tranny on... i pulled it down and counted the splines on the shaft for the stock tranny (20) then counted for the new tranny (21) now aint that some bs!!
Old Jan 6, 2009 | 09:01 PM
allgo88's Avatar
Default Re: Transmission hell!!!
88s are different than 89-91.
Old Jan 6, 2009 | 09:19 PM
D16SiHatch's Avatar
yep. you'll need an 89-91 clutch, and i believe flywheel also.
Old Jan 8, 2009 | 04:48 AM
miamiboy91's Avatar
dam
Old Jan 8, 2009 | 05:03 AM
~sp33~'s Avatar
EFB055
That would suck, go back and take what you need from the donor car before someone else does.
Old Jan 8, 2009 | 07:45 AM
allgo88's Avatar
also,axle splines are different between si,dx,and hf at the hubs.
Old Jan 8, 2009 | 08:46 AM
4drEF's Avatar
Keyboard Humorist
The way you wrote it seemed a little sonfisuing.
I believe SI, EX, LX, DX are all the same, but the HF and STD are different.
Not sure what it matters though since he's changing out the transmission and not the hubs.
Stock axles shoudl work just fine.
Old Jan 8, 2009 | 08:53 AM
EmminoDaGreat's Avatar
At least its just a clutch ya need to get.
Old Jan 8, 2009 | 08:57 AM
skidmarkroyalty's Avatar
just use junk yard tranny and get a new clutch. the clutch for the 89-91 were bigger two. bigger=better in my book.
Old Jan 8, 2009 | 02:35 PM
sanimalp's Avatar
$cat /dev/urandom
that is incorrect. the 89-91 clutch is ALREADY the problem.. he has an 88 trans, denoted by the fact that there are 21 splines on his new junkyard trans.
an 88 accord clutch disk has 21 splines, like what you need, and a 212mm clutch face to fit your 212mm '90 civic flywheel and 212mm '90 civic pressure plate. buy one and your problem will be solved. ACT even makes an "upgrade conversion" kit for that exact application, 88 trans to 90-91 flywheel/pressure plate.
this information is irrelevent. they are only different beteween 2 sets of cars. the first set is the si and dx cars, and the second set is the HF and std set. Either way, your statement is irrelevent for the op's problem, because he can use his existing axles that match his existing hubs, because the transmission side of ALL of the axles in the ef d-series are the same for USDM model cars.
Old Jan 12, 2009 | 10:21 PM
anthrax718's Avatar
i would like to do that but i got a brand new exedy stage 1 clutch in that i didnt even have for 2 months and i have a f1 8lb flywheel.....so what trannny will i have to switch that for for it to work
Old Jan 13, 2009 | 07:19 AM
sanimalp's Avatar
$cat /dev/urandom
That depends on how many splines the clutch you want to use has.
if you have both the transmissions off the car, you can test fit the clutch disk to the transmission by sliding it on the input shaft of the transmission. The transmission the clutch fits on is the one that should go into your car, unless you want to buy a new clutch.
Old Jan 13, 2009 | 08:54 PM
Noodle wAgon's Avatar
the sun is hot!?!?
Old Jan 13, 2009 | 10:46 PM
anthrax718's Avatar
i already have the clutch installed so will it be easier to just find the right tranny or change the clutch
Old Jan 14, 2009 | 10:56 AM
sanimalp's Avatar
$cat /dev/urandom
the input shaft of the transmission will have 2 machined rings on the end if it is a 90-91, and no rings on the 88.
Old Jan 14, 2009 | 12:36 PM
JustAnotherRex's Avatar
Are you really asking this?
Changing a clutch is far easier than finding a decent shape cable tranny, IMO.
-tc-
Oct 25, 2005 07:44 AM
Bond
13
Mar 15, 2005 02:59 PM
Icey112
Jul 29, 2004 04:23 PM
