99 SI Headunit into a 96-98...?
Old Aug 5, 2002 | 02:45 PM
VoltageLS's Avatar
New User
Default 99 SI Headunit into a 96-98...?
What adapter do I need to fit a SI CD player from a 99 into a 97 dx? Don't know if it'll bolt up or not, so id figure i'd ask. Thanks!
Old Aug 5, 2002 | 03:44 PM
MPower332TI's Avatar
Default Re: 99 SI Headunit into a 96-98...? (PatrickEwing)
i have one in my 98 dx....it slides right in the hole and fits pretty nicely with very little modification....as for the wiring u have to have the 99+ plug..cut ur plug and then match all wires with the 99 plug..they are all the same color..very easy..looks great...good luck..
Old Aug 5, 2002 | 05:47 PM
VoltageLS's Avatar
New User
Default Re: 99 SI Headunit into a 96-98...? (jDmDxTuRd)
So, i should get the harness probably from honda? How much does it usually run? And i take it that i first plug the new harness into the HU and then remove the plug from the 96 98 and match the wires into the 99 harness..? Thanks guys...let me know!
Old Aug 5, 2002 | 05:50 PM
d0nkeyxPunch's Avatar
Banned
Default Re: 99 SI Headunit into a 96-98...? (VoltageLS)
Why don't you just get a new headunit? It would save you the trouble and looks better. Just my opinion though.
Old Aug 5, 2002 | 07:02 PM
VoltageLS's Avatar
New User
Default Re: 99 SI Headunit into a 96-98...? (FastxCivic)
Well to answer that question there are a number of reasons.
1. ~ $80 for an SI headunit. vs. $199 + for any halfway decent HU.
2. STOCK headunit look...compared to "please rip up my dash just to get at this"
fancy HU.
3. Amber illumination to match the SI cluster and the amber climate controls...I
know this can be had on aftermarket headunits, but refer to reason # 2.
Although i'd like a nice sound system...i've just heard too many horror stories about big money systems all having to do with either deaf drivers, stolen property or Escalades on 22s.
Old Aug 5, 2002 | 07:46 PM
VoltageLS's Avatar
New User
Anyone have part #'s for what i need? Thanks
Old Aug 5, 2002 | 09:35 PM
TurboBumblBee's Avatar
do you have keyless entry on your car now?? if so you are gonna need to wire it so that that stock headunit still gets power and everything.. since keyless is part of the headunit 96-98 i install car stereos everyday and there is a harness you can get from circuit city to do this.. not that tough, just use your brain.. good luck
Old Aug 5, 2002 | 09:42 PM
RR98DX's Avatar
just goto circuit city and get a "reverse harness" for a 99 civic and a regular stereo harness for a 96-98. like $25 for both, just match the wires and you're set.
Old Aug 6, 2002 | 12:25 PM
B96v6's Avatar
Default Re: 99 SI Headunit into a 96-98...? (RR98DX)
Actually, I just did this and it was only $8 for the harnesses. Then, I just spliced the wires together (colors match up from both the harnesses). After that, plug and play! IM me if you have questions.
B96v6
Old Aug 6, 2002 | 05:45 PM
VoltageLS's Avatar
New User
Default Re: 99 SI Headunit into a 96-98...? (B96v6)
Sent you an IM!
SMOOTHN
Sep 27, 2008 07:17 AM
StOnErTuNinG
Aug 4, 2006 07:53 AM
AutoBoxEng
Jan 24, 2006 12:02 PM
JforJonathan
Sep 14, 2004 03:49 AM
shadykit
May 24, 2004 10:16 AM
