stage 4 competition clutch 6 puck problem
Old Jan 6, 2009 | 04:36 PM
newtype_33's Avatar
Default stage 4 competition clutch 6 puck problem
i installed a stage 4 clutch on my gsr,replacement for my stage 1 exedy with flywheel use the same flywheel with the stage 4 clutch after installing it gears wont go in on a high rpm flywheel has been resurface,new cylinder slave and master...i`ve seen a lot of guys with same problem is there any reason why me and other people have the same problem with the clutch?
Old Jan 6, 2009 | 05:11 PM
RedR's Avatar
Default Re: stage 4 competition clutch 6 puck problem
got the same problem as yourself.
Old Jan 6, 2009 | 05:50 PM
Turbo-charged's Avatar
edited....
call comp and talk to them. they usually handle warranty stuff pretty well.
Old Jan 7, 2009 | 02:34 AM
newtype_33's Avatar
its brand new not even 100 miles...i took it apart today i found the release bearing got to much play right to left,in and out ok.i want to get my money back.i decided to used stage 2 excidy.
Old Jan 7, 2009 | 07:49 AM
turboedsupe's Avatar
Welcome to the club man i have the same problems
Old Jan 8, 2009 | 03:26 AM
RedR's Avatar
i got in touch with them, described the problem and did what they asked me to.
Still they said it could be anything but their clutch lol, and the previous one was just fine (ACT), i only took it out to sell it since with the new setup i was aware it wouldnt last...
Old Jan 8, 2009 | 08:35 AM
Full-Race.com's Avatar
Originally Posted by newtype_33
i installed a stage 4 clutch on my gsr,replacement for my stage 1 excidy with flywheel use the same flywheel with the stage 4 clutch after installing it gears wont go in on a high rpm flywheel has been resurface,new cylinder slave and master...i`ve seen a lot of guys with same problem is there any reason why me and other people have the same problem with the clutch?
You mentioned that you changed the master cylinder. Could it be possible that the clutch pedal isn't properly adjusted maybe?
Old Jan 8, 2009 | 04:26 PM
newtype_33's Avatar
i did an adjustment already....i only change them because i had this problem with this clutch....guess what i installed my stage 2 excidy and i dont have any issues at all!im going to call comp tomorrow and find out what they say...
Old Jan 8, 2009 | 06:57 PM
pheonixb16aguy@hondaswap's Avatar
is excidy a new company ?? lol
Old Jan 8, 2009 | 07:05 PM
newtype_33's Avatar
i mean exedy heheheheeh lol ....
Old Jan 8, 2009 | 07:11 PM
garage16.ca's Avatar
I sold a few Stage 4 competition clutch 6 puck kits for the GSR and never had a problem with them. In fact I never had a problem with a competition clutch at all
Old Jan 8, 2009 | 09:07 PM
newtype_33's Avatar
dont know bro but as you can see im not the only one.
Old Jan 9, 2009 | 12:52 PM
90teg's Avatar
I had the same problem with a stage 4 and a stage 5 cc. I went with a exedy twin, and all my problems went away.
Old Jan 9, 2009 | 02:21 PM
newtype_33's Avatar
as i`ve said im not the only one....
Old Jan 9, 2009 | 02:53 PM
ctr_ek209's Avatar
havent had one issue with comp. clutch
Old Jan 9, 2009 | 10:04 PM
blinx9900's Avatar
wow this is insane, comp needs to do something about this.
Old Jan 10, 2009 | 05:35 AM
turboaap's Avatar
Call them thay are verry good to the people that use there product and will go as far as thay can to help any of us. I will say that thay do recomend that you use there flywheel with the clutch kit. Also how mutch HP do you have my ACT did this to me it was time for a twin disc and some solid mounts.
Old Jan 11, 2009 | 12:55 PM
portenio78's Avatar
I have a problem with my CC stg4. It seems to have a mind of its own. Sometimes it hold and sometimes it doesnt. It all happens very speraticaly and is inconsistant. I'm doing some other changes to my setup and have already purchased a new flywheel...just in case this is my problem. When its done we'll see how it acts.
Old Jan 12, 2009 | 08:35 PM
newtype_33's Avatar
let us know....
Old Jan 15, 2009 | 06:19 AM
Racer Chic's Avatar
Had mine in the turbo Civic for over a year now without any issues. What did they say was the cause of the problem?
Old Jan 15, 2009 | 12:14 PM
kevinz's Avatar
I had a CC stage 4 with a good amont of races on it, but the disk was missing some chucks of material after inspection. I called CC they told me it overheated, they recommended the stage 5 clutch, that clucth only lasted maybe 10 passes down the track and then high shifts where impossilbe without grinding and other noises, after inspection of that clucth one of the three rivets let go causing some damage. I remember that guy from CC said you cant break the stage 5. I have an all motor car. I ended up going with a twin disk from another company with no problems so far. But the whole rivet issue was the only one I have seen or heard from my research so it could be a fluke in the assembly process.
Old Jan 21, 2009 | 02:51 PM
92redsihatch's Avatar
dude, wtf? i just orderd my stage 4 CC for my GSR today. hope it doesnt happen to me
Old Jan 21, 2009 | 07:26 PM
SilverEk3dr's Avatar
Had the EXACT same problem with mine. Stage 4. Adjusted it. Changed slave. Blead the system out. Adjusted again. same crap. Had the tranny out about 5 times that day.
Turns out it was my crappy aluminum flywheel. So I said fck it and ordered one of their flywheels and that cured it. Only probs I have now is that it will scratch going into 3rd or 4th at high rpm. Tranny shifted like butter with the stock clutch! Going with a twin disk as soon as I kill this one.
Old Jan 21, 2009 | 07:30 PM
EARLdaSQUIRREL's Avatar
official honda whore
im having problems with my clutch not disengaging , i literally have to rip it out of gear when coming to a stop sometimes
stage 5 with flywheel and brand new clutch master and slave cylinders adjusted properly
Old Jan 21, 2009 | 07:45 PM
mar778c's Avatar
Community Builder
Community Influencer
Damn, this is not the type of news I want to hear. I'm seriously considering a CC set-up.
