Zc
is the zc considered a decent swap into a 91 civic and is it a driect bolt up as far as motor mounts and engine harness and ecu and axles....i currently have a D15B2 with a 4 speed if im not mistaken they r shorter than the axles out of a 5spd civic...only reason im considering a 140hp zc over a b16a is cause of money isseus...or if i should bare down and save for a b16...ne help or comments would be greatly appreciated
ZC is way cheaper, and same with buying D series parts over B series. DOHC ZC is only 130, but about the same torque as a B16, and only 30 less HP. It is a direct swap, but you need to be MPFI, not DPFI, and you will have to rewire your distributor wiring... There is a huge FAQ, that should answer all of your questions, stickied at the top of this forum.
PGM-FI stands for ProGraMmed Fuel Injection.
There are two variants Honda used on our era of cars.
DPFI is Dual Point
MPFI is Multi Point
- DPFI uses 2 injectors that spray into a chamber that feeds all 4 cylinder intake ports. It's similar to a carburator as one injector is used as the main source of fuel and the secondary/auxiliary injector comes on when extra fuel is needed.
- MPFI utilizes 4 injectors that feed each cylinder individually.
MPFI is on the left - note the 4 injectors.
DPFI is on the right - if your engine has that big black chamber then it's DPFI
DPFI is Dual Point
MPFI is Multi Point
You can still do the swap regardless if you are DPFI or MPFI.
DPFI requires that you do a little wiring and such (it's NOT difficult!) as pointed out by theidealone
The 4 speed tranny will bolt up, but I think you should go after a 5 speed Si tranny to make better use of the new engine. You won't have to buy axles - your stock axles should be fine.
well i appreciate all the input..im still a rookie and just tryna learn lol....and yea i think ill get a 5spd and because of bein a cable tranny ive had some input on changin the final drive gear to a 4:71 is that a good or bad idea
I wouldn't open the tranny as you state you are a 'rookie'. It's good to know your limits.
Maybe if you feel the urge to upgrade after you get this swap done, pick up a spare Si tranny and do a ZC 1~4 gear swap, LSD, along with a clutch and flywheel upgrade
yea im sure itll be just fine....now i read that faq on the swap should i use the ecu that comes with swap for better performance or theres not much differnce between the ecu i already have and that ecu with the zc
