weird idle help
i have a 98 civic cx sir swap. car ran fine till i put a skunk2 mani on know it idles high till it warms up then the idle bounces. i pulled mani off and checked for vac lead and reinstalled new gasket. same deal what else could it be. iac is torqued down new gasket on it. throttle body new gasket. pretty much everything new gaskets. that is why i don,t understand. Please help. thanks
Is the CEL ON?
Spray some carburetor cleaner around intake gaskets and vacuum hose connections (brake booster, cruise control, PCV, etc.). Any change in idle speed would indicate a leak.
thanks. i have no cel and i have tried carb cleaner and it is around the third injector it bogs down when i spray it. my fuel rail isolators are broke so i wonder if my injectors are not seated all the way. i am putting new ones in today maybe that will work. if not it may be iacv. i hope not it is like $211.
SOHC_civic_si
16
Dec 29, 2010 02:25 PM
95dc2teg
Sep 11, 2007 05:49 PM
pimpami333
Feb 13, 2007 10:30 AM
