rsx wont start up
anymore info than that? Like are you sure it's got a good battery? Plenty of power? Do you live in a cold place like me where you could have gotten water in the fuel system and now it's frozen.
from what you've stated it may need a fuel pump or filter. it could be flooded. sometimes when there is a big change in temperature and a sensor is going bad it will flood. or worst case scenario it has jumped time. try holding the gas peddle to the floor and starting it. dont paddle it. if it doesnt start then you can rule out flood. after that i would check the pump and filter.
hope this info helps you.
