Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Car Accident, hopes it's minor...
Old Jan 5, 2009 | 03:03 PM
Wthorp's Avatar
Default Car Accident, hopes it's minor...
So anyways, I was at a light coming outside the Resort I work at. The car in front of me suddenly reversed and I reacted and I reversed. Well I totally forgot, but my resort had a sign behind me and I went backed up into it. My driver back tire jumped up and my bumper hit the wall.
Anyways, when I drove away, cause I only saw damage to my bumper, I noticed a loud rubbing noise and the back tire on the driver side was litterally bent inwards by a few degree's. I looked under the car, and the drum has a arm snapped off a holder. I will try and take a picture, but everyone is telling me it's the lower control arm, and I looked and it kinda does look like it.
My question is, how much will it cost me to repair this at a shop and is it do-able at my own house if I have a set of Snap-On's and also an air compressor.
Old Jan 5, 2009 | 04:25 PM
Igaly's Avatar
Default Re: Car Accident, hopes it's minor...
with what your saying it sound like the is the lower control arm you can do that yourself at home it's not that complicated to do, but remember after replacing the lower control arm you need to take it to a shop to get a rear end alligment......don't take it to a shop to get that done bro were from florida you how expensive theses guys charge
Old Jan 5, 2009 | 05:16 PM
Wthorp's Avatar
especially from in our Kissimmee and Orlando area. Heh, a front alignment cost me 65 Dollars -.- and they tried telling me I needed my belt changed when I had changed it two weeks prior
Yeah, I guess I jsut need to read up and make sure I can a basic idea of how to do it.
Old Jan 5, 2009 | 07:09 PM
It Wasn't Me's Avatar
Jack up the car, remove the wheel, take photos from a couple different angles, post them here.
If it's just the LCA and nothing else was damaged, repairing it yourself will be easy and inexpensive.
Old Jan 11, 2009 | 12:31 PM
Wthorp's Avatar
Ok,
I can't find my camera and I was told I had to replace the entire rear suspension hub spindle witch sucks. However the spindle's don't have the peice I broke on my car.
http://i43.tinypic.com/2hgwn0n.jpg
^ a picture of a spindle I will be getting. However, the circle is what confuses me. That LCA looks nothing like what I have on my car. My lca looks more like it the Front LCA. :/
Old Jan 12, 2009 | 04:32 PM
Wthorp's Avatar
http://i44.tinypic.com/27yu2rq.jpg
Ok I took the tire off. The above is a picture of a right side Hub Spindle for my make and year. What I circled is what is broke on my car, but it's broke on the DRIVER side hub spindle. I am only using the above picture to ask for that part.
If that piece is broke, do I need to replace the whole Hub Spindle, or could I just replace what is broke?
If I need to replace the spindle, is this a decent one? : http://cgi.ebay.com/ebaymotors/01-02...4506.m20.l1116
Old Jan 12, 2009 | 09:41 PM
chaserz's Avatar
I had the exact same problem, except mine was much worse.
https://honda-tech.com/forums/showth...406&highlight=
Basically you are probably gonna have to replace the Trailing Arm (the huge bent cylinder that connects the knuckle, spindle, lower control arm, etc.). If you buy the trailing arm it should include a lower control arm, since you cant replace that by itself unless you have the right tool anyways. Also, you're probably gonna have to replace the sway bar, since that most likely bent also.
Truth is, you can do it all yourself, even though i had someone do it for me. I bought my parts on majestic Honda. You probably dont have to replace anything else. Hope this helps. PM me if you need any more info.
Old Jan 12, 2009 | 09:59 PM
.Ash's Avatar
I'm parting an 03 ex 4dr; if the parts are the same I can help you out.
Old Jan 13, 2009 | 10:54 AM
Wthorp's Avatar
How much did it cost?
Old Jan 15, 2009 | 05:44 AM
chaserz's Avatar
Price for parts itself were about roughly 250 for the trailing arm, sway bar, and a few bolts/bushings.
sohctodohc
Suspension & Brakes
11
Sep 13, 2005 11:40 AM
thomst4R
Suspension & Brakes
Jul 17, 2005 06:20 PM
extracrunchie
Dec 20, 2004 09:47 AM
egamjah
11
Jun 6, 2004 01:22 PM
skyliner186
11
Dec 29, 2003 08:39 PM
