Scary Brake Problem 90 EF sedan
ok this is a real hazard that i have yet to fix.
say im at a stop light, i have my foot on the brake completely stopped. then before i know it, im rolling either forward to back and my brake pedal slowly sinks to the floor depending on the amount of pressure im giving it.
one i left my foot all the way up, press back down, its normal again. i have to have the pedal compressed for about 15 seconds then it sinks down and i start rolling.
im not leaking any fluid, im topped off on fluid. only thing i can think is air bubbles.
any thoughts?
any thoughts?
oh yea seriously. i'll go to pick a part sometime probably this weekend and see if i can strip one. i'll just get the whole assembly, well not the resevoir.
Don't bother with pick-a-part.
It's your brakes and it's not worth it using junk car parts for your safety.
I believe a rebuild from a autoparts store will run you about $50 and will come with bench bleeding kit and instructions.
Yeah the master cylinder isnt that expensive..
http://www.autozone.com/N,14400007//...eResultSet.htm
