b16 tranny grinds at high rpms?
Old Jan 5, 2009 | 02:48 AM
miamiboy91's Avatar
Default b16 tranny grinds at high rpms?
do i need a new clutch possibly?
Old Jan 5, 2009 | 03:05 AM
fltblkEFhatch's Avatar
Default Re: b16 tranny grinds at high rpms?
only a certain gear, or all gears?
Old Jan 5, 2009 | 04:33 AM
miamiboy91's Avatar
all
Old Jan 5, 2009 | 07:26 AM
BSeriesRescueteam's Avatar
Synchronizers possible. Time for a tranny rebuild!!!
Old Jan 5, 2009 | 05:22 PM
just tighten the clutch cable, and if it still does it...it's most likely synchros
Old Jan 6, 2009 | 11:55 AM
miamiboy91's Avatar
dam dat suks ill try to tighten the clutch cable thanx
Old Jan 6, 2009 | 12:00 PM
miamiboy91's Avatar
how much would the rebiuld be just to replace the snchronizers
Old Jan 6, 2009 | 12:03 PM
Targa250R's Avatar
be professional
Replacing every synchronizer set will net you a bill with a 4-digit figure.
If every gear is grinding, it's not a synchronizer problem. It's likely clutch cable adjustment or a worn clutch disc. Also check the fluid level in the transmission and make sure it isn't leaking.
Is the transmission making any sort of whining noises at any time?
Old Jan 6, 2009 | 06:22 PM
RB_EJ8's Avatar
When I step on the gas pedal I get the whining noise, when I release the pedal it goes away, WTF?
I just picked up a b16a rebuilt tranny from a reputable shop. They put a new clutch, resurfaced the flywheel, no grinds, shifts like butter. I get a little whining noise when I step on the pedal. Should I worry about it?
Old Jan 7, 2009 | 04:19 AM
miamiboy91's Avatar
i have no wining noise it only happens when i shift really fast or high rpms
Old Jan 7, 2009 | 08:05 AM
Targa250R's Avatar
be professional
In every gear? Including 4th and 5th?
Sounds like you either need to learn how to time your clutching with your shifting, or adjust your clutch cable.
Old Jan 7, 2009 | 09:01 AM
well...that is known to happen with hardened gears....but if you got oem gears, i would ask them if they for sure replaced the input shaft bearing...also...when the car is idling and the clutch is released, do you hear any kind of noise at all from your tranny, (play around with the pedal while the car is idling...)
Old Jan 7, 2009 | 09:41 AM
RB_EJ8's Avatar
They replaced the input shaft bearing along with it with OEM aftermarket syncros, and sliders. I was playing with the car on my way to work and I didn't hear any whining noise. Its been day 2 since I got it back from the shop. No noise at all. Thanks for the help guys!
Old Jan 8, 2009 | 04:40 AM
miamiboy91's Avatar
it makes no kind of noise at all and in 4th it does it very mild and 5th it doesnt do it much
bradennicely
Apr 23, 2010 07:37 AM
slow88crx
Dec 24, 2008 04:22 AM
bambbrose
Sep 6, 2005 04:21 PM
Jeff
12
Apr 8, 2005 12:02 AM
91HATCH
11
Jan 14, 2002 06:47 PM
