99 si - 4th gear grind
Old Jan 5, 2009 | 01:35 AM
farikanok's Avatar
Default 99 si - 4th gear grind
hi,
looking for some help with a 4th gear grind on a '99 civic. so, if i change gears 3 to 4 normally (like i do from 1 to 2 or 2 to 3), then i get a loud grind that doesn't go away unless i go back to 3 and try again. this doesn't happen if i rev up to about 3500 rpm. also, if i rev to about 2700 rpm and press the clutch, then shift into 4 while very slowly releasing the clutch, it's okay. but during this, the car has to slow down a little so it's not very smooth.
so, i was wondering if anyone has an idea or a list of possibilities of what this might be? a friend told me it might be the synch, but i'm not sure...
thanx in advance.
Old Jan 5, 2009 | 01:52 AM
andoxviii's Avatar
Default Re: 99 si - 4th gear grind
Synchros.
You should check that your transmission fluid is at the proper level, but it may be best to replace it with genuine Honda MTF or GM Synchromesh. Both are known to help transmission grinds, but don't expect a miracle here.
Unfortunately, the only way to truly remedy the problem is to rebuild or replace the transmission.
Old Jan 5, 2009 | 05:30 AM
roadsqueegy95's Avatar
i had same thing happen in my old vtec del sol, it was the Synchros, so i just traded it in on my EM1
Old Jan 5, 2009 | 05:44 AM
00b20vtecoupe's Avatar
u probbaly have a clutch thats getting worn out and it got into a fist fight with ur syncros. i had the same prob with 3rd gear in my b16 i got a new set from honda for like 230 bux and had a friend rebuild it for like 100 bux.
Old Jan 5, 2009 | 08:14 AM
Juan_Mitosis's Avatar
Same thing I did. Dropped the transmission myself, bought the 3-4 Honda synchro set ( after my mechanic said that was all I needed ) for around $168 And he replaced it and resealed my transmission for $90 ( BIG time friend). Then just take advantage of that and get a new clutch kit and your flywheel resurfaced while you're at it!
Old Jan 5, 2009 | 09:03 PM
farikanok's Avatar
thanks for the input guys. i'm gonna take it to honda to have them test drive it for free and get a friend to change the synchros. hopefully that'll take care of it.
jpuleo
Aug 9, 2015 01:47 PM
Bseriescivic5
Transmission & Drivetrain
Mar 31, 2010 11:45 AM
bsemaan
Dec 26, 2004 05:50 AM
Greg James
Aug 17, 2004 06:05 PM
