car won't start need help already read everyone won't work topics
Old Jan 4, 2009 | 03:38 PM
kreeper's Avatar
Icon3 car won't start need help already read everyone won't work topics
hey i recently just got into an accident and my front end got messed up and i drove it home fine and i just finished fixing my front end and tried to start me car and it won't turn over. i heard the fuel rail its getting fuel. i check my injectors there getting fuel. checked my fuses all good, checked my kill switch everything fine, checked my belt all good, just replaced my spark plugs, cleaned my distributor cap, the wires on it is in order, adjusts it, so now what else could it be? cause like i said i drove it home still and it ran fine besides my core support was like up against my motor and my radiator got busted. so help please!!!
Old Jan 4, 2009 | 03:46 PM
mafia's Avatar
Default Re: car won't start need help already read everyone won't work topics
starter?
Old Jan 4, 2009 | 03:47 PM
kreeper's Avatar
yeah checked that too. thanks thou. can you think of anything else
Old Jan 4, 2009 | 03:48 PM
IhateworkingoncaRs's Avatar
Battery
Old Jan 4, 2009 | 03:49 PM
kreeper's Avatar
yeah checked that to its a brand new battery. thanks thou. anything else
Old Jan 4, 2009 | 03:51 PM
Tuck_u's Avatar
try push starting it if that dont help remove ur kill switch and try again. check ur alternator belt for slack.
Old Jan 4, 2009 | 03:57 PM
kreeper's Avatar
yeah i already tried all of that. and all ready took my kill switch off and wired it back up to normal.thanks thou.
Old Jan 4, 2009 | 04:09 PM
buhda0422's Avatar
try connecting a battery charger to it and see if it helps
Old Jan 4, 2009 | 04:17 PM
kreeper's Avatar
yeah had my buddy car trying to jump mine too. thanks thou
Old Jan 4, 2009 | 04:18 PM
Sr420Det's Avatar
Maybe it got overheated and once everything contracted it seized up. Can you rotate it by hand. The problem is its not turning over at all right?
Old Jan 4, 2009 | 04:20 PM
kreeper's Avatar
yeah i can. but yeah not turning over at all. =/
Old Jan 4, 2009 | 04:21 PM
Sr420Det's Avatar
Is the starter getting power?
Old Jan 4, 2009 | 04:24 PM
kreeper's Avatar
yup it is.
Old Jan 4, 2009 | 04:43 PM
91_integra_JDMswap's Avatar
Check the rotor ignition inside of the cap...it could be worn out and not hitting all of the points.
Old Jan 4, 2009 | 09:46 PM
kreeper's Avatar
i didn't check that yet. get at me if you can think of anything else
Old Jan 4, 2009 | 10:17 PM
Stock90Civic's Avatar
Have you checked for spark? Hold one of the spark plug wires to a bolt and try to start the car.
Is it cranking and just wont start or not even cranking?
Chris
Old Jan 4, 2009 | 10:20 PM
drift2004's Avatar
u have not said u have spark, check spark, if there is no spark replace the rotor if its burnt,
Old Jan 4, 2009 | 10:22 PM
Could be more then just the rotor and cap. Could be the pcm or something like that.
Old Jan 5, 2009 | 03:05 PM
Sr420Det's Avatar
He said it wasnt turning over at all. So lets get this thing spinning so you CAN check spark.
Old Jan 5, 2009 | 03:11 PM
r33dm0n3y's Avatar
have you double checked all of your grounds?
Old Jan 5, 2009 | 06:18 PM
kreeper's Avatar
just got a new rotor and coil about to replace it... yeah there wasn't no spark.. thanks guys well i get back at you guys after i put it back in my car
Old Jan 5, 2009 | 06:27 PM
kreeper's Avatar
it runs thanks everybody but now my cars smoking hella whys that?
Old Jan 5, 2009 | 08:20 PM
What color smoke? Any smell?
Old Jan 6, 2009 | 12:50 AM
zcar4me's Avatar
Wait, so what the hell was it? Why was your motor not turning over? And why did you still drive it when the "core support was like up against my motor and my radiator got busted."
Old Jan 6, 2009 | 01:57 AM
kreeper's Avatar
my core support i used a stock jacked and put it up aginst my block and the core support and jacked it apart till it came out as far as i needed it to then did some banging and pulling. i had to buy a new radiator. an the problem was my coil in my distributor then it ran. just the alignment is ****ed up... thanks for all yours guys help i appreciated it...
