car won't start need help already read everyone won't work topics
hey i recently just got into an accident and my front end got messed up and i drove it home fine and i just finished fixing my front end and tried to start me car and it won't turn over. i heard the fuel rail its getting fuel. i check my injectors there getting fuel. checked my fuses all good, checked my kill switch everything fine, checked my belt all good, just replaced my spark plugs, cleaned my distributor cap, the wires on it is in order, adjusts it, so now what else could it be? cause like i said i drove it home still and it ran fine besides my core support was like up against my motor and my radiator got busted. so help please!!!
Re: car won't start need help already read everyone won't work topics
yeah checked that to its a brand new battery. thanks thou. anything else
try push starting it if that dont help remove ur kill switch and try again. check ur alternator belt for slack.
yeah i already tried all of that. and all ready took my kill switch off and wired it back up to normal.thanks thou.
Maybe it got overheated and once everything contracted it seized up. Can you rotate it by hand. The problem is its not turning over at all right?
i didn't check that yet. get at me if you can think of anything else
Have you checked for spark? Hold one of the spark plug wires to a bolt and try to start the car.
Is it cranking and just wont start or not even cranking?
Chris
Chris
Could be more then just the rotor and cap. Could be the pcm or something like that.
He said it wasnt turning over at all. So lets get this thing spinning so you CAN check spark.
just got a new rotor and coil about to replace it... yeah there wasn't no spark.. thanks guys well i get back at you guys after i put it back in my car
Wait, so what the hell was it? Why was your motor not turning over? And why did you still drive it when the "core support was like up against my motor and my radiator got busted."
my core support i used a stock jacked and put it up aginst my block and the core support and jacked it apart till it came out as far as i needed it to then did some banging and pulling. i had to buy a new radiator. an the problem was my coil in my distributor then it ran. just the alignment is ****ed up... thanks for all yours guys help i appreciated it...
