to much fuel
i just did a motor swap into a 97 civic its a 95 gsr but has all been converted to OBD2 ( injectors, altanator, distrubuto exc.) and now cylinder 1 is getting wayyyy to much fuel my fuel press is 35 psi and none of my injectors are stuck open and they are pulsating what could be the issue?? is the only thing stoppin me fron drivin my car
ya i just did all that and im not runnin an air box or intak just the throttle body ive swapped injectors a good 4 times i used obd1 first then swapped to the obd2 and then to dsm not im back to the stock 97 gsr injectors
that could be the problem. DSM are low impedance injectors (peak hold) (3 ohms ~) b series im not sure but h and f and high impedance (saturated) (12+ ohms ~). You may have done something to the ecu
