Walbro 255 low or high pressure pump???
Old Jan 3, 2009 | 03:36 PM
boosted91REX-SI's Avatar
Icon2 Walbro 255 low or high pressure pump???
I am wanting to buy a new fuel pump for my 93 integra with a b18 gsr...i have decided to go with the walbro 255, but i what i need to no is do i need a high pressure fuel pump or a low pressure fuel pump....or does it really matter??? I do plan on boosting the car eventually and upgrading the injectors of course...i have takin a look around here and havent found nothing on it...any info would be great thanks in advance
Old Jan 3, 2009 | 03:53 PM
tech7427's Avatar
Default Re: Walbro 255 low or high pressure pump???
what base fuel pressure do you want to run? im thinking the base walbro 255 will be fine
Old Jan 3, 2009 | 11:50 PM
they dont have a base model...i believe?...i went to tunertoys and its either low or high pressure???
Old Jan 5, 2009 | 08:23 PM
blinx9900's Avatar
there is normal and there is the HP, the HP is for people who run high fuel pressures, one example people with a boost dependent FMU... honestly though i always just get the HP, for $10 more why not...
Old Jan 6, 2009 | 12:12 AM
95nacoupe's Avatar
higher fuel pressure = hotter fuel
Old Jan 6, 2009 | 12:23 AM
jdm602's Avatar
lol. so you would rather starve your motor?
gotta get fuel to the motor somehow. would you have it slow and make not as much power than you could if you had the pressure for it? especially when it comes to ethanol. i wish i would of gotten the hp now. ill be replacing my low pressure one with an hp one.
oh and heat doesnt affect it as much as you think.
Old Jan 6, 2009 | 12:27 AM
blinx9900's Avatar
What does that have to do with anything in this thread?
A high pressure fuel pump is not going to change your fuel pressure, thats what the FPR does
Old Jan 6, 2009 | 01:50 AM
95nacoupe's Avatar
PS: I LOVE THE ****
What are you talking baout starve the motor? Its a stock gsr, there is no need for a 255 at all.
Old Jan 6, 2009 | 02:05 AM
blinx9900's Avatar
What are you taking about? Its going on a turbo motor, every post you make makes me question your expertise more and more...
Old Jan 6, 2009 | 02:12 AM
95nacoupe's Avatar
I think you should read over the OP. It says that he wants to boost the car down the road. Since he does not know what he is going to do as of now it would be a poor decision to put a hp255 in because his works and he may need an external a few months down the road depending on the build.
Old Jan 6, 2009 | 02:13 AM
95nacoupe's Avatar
Also it does not say I NEED a fuel pump, it says that he is wanting. I think its time for some new glasses.
Old Jan 6, 2009 | 02:23 AM
95nacoupe's Avatar
And in response to this the fpr regulates the pressure that is in the line coming from the fuel pump and the line feeding the fuel rail. When you prime the fuel system (turn the key) the pump is going to push out max pressure then the fpr regulates how much pressure get through to the fuel rail.
Old Jan 6, 2009 | 03:07 AM
blinx9900's Avatar
Why would he need an external? i have seen a single walbro support 550whp, do not need to reread anything, are you suggesting he do the same job twice?
where did i say he said he "needs" a fuel pump?
i see what your getting at now, it appeared as if you where saying raising fuel pressure will increase the temperature of the fuel, which is not correct.
Old Jan 6, 2009 | 11:42 AM
jdm602's Avatar
dude your f***ing retarded. just quit posting.
he said he wanted to turbo it. also it doesnt matter having an upgraded fuel pump on a stock motor, it wont hurt anything. and i doubt hes gonna wanna get an external pump by the sounds of him asking if he should get a 255 lp or hp, especially specifying a walbro 255. doesnt sound like its gonna be a race car or anything.
and why are you telling us how a fpr works. nothign to do with what the guy is asking.
either way boosted91REX-SI, either 255 supports a lot of power. high pressure a little more. im sure a low pressure will work just fine, as well as the high pressure. its a matter of personal choice.
Old Jan 9, 2009 | 12:15 AM
95nacoupe's Avatar
your retarded if you think someone needs a 255 for a stock motor
Old Jan 9, 2009 | 04:52 AM
blinx9900's Avatar
Nowhere in this post did he say that.
BobbyRodriguez
Aug 18, 2012 12:00 AM
FlewByU352
Jan 2, 2012 05:41 PM
TurboSpoolinInside
Jul 24, 2011 06:06 PM
1SlowSi
Nov 9, 2004 01:13 AM
zojirushi
Sep 30, 2002 11:00 AM
