connecting the deck
Old Jan 3, 2009 | 12:19 PM
DARS_C_C's Avatar
Default connecting the deck
i got a kenwood deck but i dont know how to connect it to the wires in my EG.
how do you do?
Old Jan 3, 2009 | 12:24 PM
wvudelsol's Avatar
Default Re: connecting the deck
go to walmart and buy the wiring adapter for hondas..It's under 10 dollars
Old Jan 10, 2009 | 07:29 PM
DARS_C_C's Avatar
my wires are ripped
Old Jan 10, 2009 | 07:42 PM
DeLsLo95Si's Avatar
I had the same probelm, What I did is went to my local Car stero store and ask If I could have the wire color code hook up for my car, and they printed it off and gave it to me For no cost.
Old Jan 10, 2009 | 08:13 PM
punkinbeck's Avatar
get wiring diagram from haynes chilton or helms. They're easy to read
Old Jan 10, 2009 | 09:10 PM
thumper64's Avatar
I got the same problem. Previous owner was a dumbass and cut the wires, then connected them back with butt connectors. They probably didn't use an adapter harness with the old radio and tried to patch it together for the one it had in it. I'm running dedicated speaker wire when I get a chance to pick it up.
Here's the diagram with wire colors to identify it all. Just print out page 6. Hope it helps ya bud.
http://www.installdr.com/InstallDocs...PDF/466017.pdf
Oh, and if you can remove the harness, either get a good one or solder that one back together with an OEM connector on the end. Then either use heat shrink tubing or liquid electrical tape.
dmc12321
Audio / Security / Video
Jun 29, 2014 02:09 PM
HT Chaplain
Welding / Fabrication
Jun 14, 2010 08:50 AM
IGGY
Oct 10, 2006 09:46 AM
thinkbrianthink
Mar 6, 2003 08:52 AM
