Starting Issue
Old Jan 3, 2009 | 12:04 PM
lude98SH's Avatar
Default Starting Issue
Well i got the car started but what fixed the problem seems kind of odd to me. The car has been sitting outside under and cover with the battery connected for about a week without being started. Battery was at 12.05 V, fuel pump primed and i had pressure at the rail. I have the battery located in the trunk. I ohmed out all the power cables and ground cables, some were allittle high so i cleaned them up. I go to start the car again and it cranks and doesnt start. I have no CEL. I have a hondata s300 unit, so next thing i did was reload the map, I crank it and it starts right up. My question is why the hell did I have to reload the map when I never disconected the battery ?
Old Jan 3, 2009 | 03:30 PM
tech7427's Avatar
Default Re: Starting Issue
maybe reloading the map was just a coincidence but it was really a bad main relay..
Old Jan 4, 2009 | 07:48 AM
fcm's Avatar
fcm
Old Fart
My question is, how did you clean the connections without disconnecting them????
" ohmed out all the power cables and ground cables, some were allittle high so i cleaned them up"
You do know that disconnecting a ground is the same as disconnecting the batt., right? 94
Old Jan 4, 2009 | 08:30 AM
lude98SH's Avatar
Yes i know that, I did that after the car would not start originally and after i had it disconnected it would not start. However to loose the map how long would you need to be disconnected ? I only had it apart for 20 mins max.
Old Jan 4, 2009 | 10:04 AM
fcm's Avatar
fcm
Old Fart
Most memories are lost almost instantly once power or ground is disconnected, unless it is stored on a ROM in the unit. 94
Old Jan 5, 2009 | 09:52 AM
lude98SH's Avatar
just spoke with hondata and they said that it should not loose the map by just disconnecting power.
Old Jan 5, 2009 | 11:08 AM
fcm's Avatar
fcm
Old Fart
Then it is held in ROM memory.
Could have been a voltage spike, what did they think caused the memory loss? 94
Old Jan 5, 2009 | 12:52 PM
lude98SH's Avatar
They said that they dont really have anyway to figure it out.....great tech support right. However i do have another issue with the car stalling while running if i disconnect the usb cable from the ecu. He said that could be a socketing issue and i would have to bring it to a dealer. However hondata themselves did the socketing about 6 months ago , if that.
Old Jan 5, 2009 | 04:09 PM
fcm's Avatar
fcm
Old Fart
Maybe both problems are related, what is the warranty on the "socketing"? 94
tempsohc
Engine Management and Tuning
32
Aug 20, 2013 05:34 AM
Circaskaterr
Oct 13, 2009 09:45 AM
Carnage R1
Jun 10, 2005 01:03 PM
Tru
Apr 11, 2005 07:10 PM
h46it
Apr 25, 2003 10:45 AM
