most bang 4 the $$$$$
Old Aug 5, 2002 | 08:59 AM
tuff^accord01's Avatar
Default most bang 4 the $$$$$
i just picked up a 01 accord and have no idea what to do to the engine i have wandered super, turbo, pulleys ,ignition cams what you know iam not reall sure if any help is out there itd be greatly appreicated.
blake kelley
Old Aug 5, 2002 | 09:01 AM
Accord94DX's Avatar
Default Re: most bang 4 the $$$$$ (tuff^accord01)
t3rb0.
Old Aug 5, 2002 | 09:14 AM
RJonathan's Avatar
Well you can start with the basic I/H/E.
Old Aug 5, 2002 | 09:31 AM
m0t0rhead's Avatar
blake kelley
Nitrous is the most bang for the buck. If you have a V6.. it'll handle a 100 shot no problem... if it's a 4 banger.. it'll handle a 60-75 shot.
[Modified by Escobar, 1:31 PM 8/5/2002]
Old Aug 5, 2002 | 09:35 AM
Stew Pidasso's Avatar
Nitrous Oxide = Most bang for the buck.Where else can you get 50-75HP for 500 bucks-maybe less for a used system.
Although ,after you keep refilling the tank it may be turbo in the long run.38 Bucks for 10 pounds of nitrous and ten tanks later your up to $880 (with original setup)still cheaper than a turbo.But then turbos do kick ***!
Old Aug 5, 2002 | 09:53 AM
Brandon's Avatar
Life is Suffering
Default Re: most bang 4 the $$$$$ (Escobar)
tick....tick....BOOM! I think you have it backwards. The v6 tranny can barely hold it's own torque, let alone the torque of the car with nitrous.
Old Aug 5, 2002 | 10:37 AM
2.2dc2's Avatar
Default Re: most bang 4 the $$$$$ (F22turbo)
go turbo..unless you jrsc makes one which i doubt. dont blow up your brand new car....but then again turbo voids warranty....buy a beater...thats what i wish i did
Old Aug 5, 2002 | 11:46 AM
denzinz's Avatar
I agree with F22Turbo....The V6 tranny is weak....You'll tweak that tranny in no time. I cant even handle a 80 hp turbo.
Old Aug 5, 2002 | 12:24 PM
KTeller8's Avatar
Default Re: most bang 4 the $$$$$ (denzinz)
the most bang for your buck.. depends on your buck. what are your goals and what do you want to spend. i can only guess you paid a good amount for your new car, so you dont want to dish out another 6k... think of where you want to be.. and how much you want to spend... that will determine a lot
Old Aug 5, 2002 | 03:51 PM
RotaryBzzz's Avatar
G-Bangin for the Buck:
Decent set of 15-17" rims with sticky tires. Try http://www.tirerack.com or the local classifieds. Check the wieght of the wheel though cause it's stupid to get bigger rims that look nice but weigh a ton (ie 18"s). Ridiculous. Rims: depends... 80-150/rim. Good tires 50-109/tire.
Set of springs...used Eibachs/H&R's for $80-100...your stock shocks should still be good enough (...don't know what kind of driving you do). Install: depends, $50+ bucks....call around.
If you have a manual trans...throw some Redline MTL synthetic oil in the tranny...fasting meshing of the synchros = faster shifting = faster revs = faster to powerband = faster car. Cost of oil = $7/quart...need 2 quarts (or there abouts).
Sharpen your driving skills...heel toe'ing...get one (1) aftermarket clip-on pedal for the accelerator pedal. This will make doing this much easier. ($10)
Strut tower bar (~$30) will stiffen up the chassis nicely - spans over the engine...
K&N filter ~$25-30 bucks. Free flowing...won't lose horsepower when it gets dirty. Gain a bit when reasonators are removed. Won't hydrolock (aka ****-up) your engine in the rain. In the words of a visiting Japanese chief engineer to APEXintegration "honda is an engine company. they build engines, then just happen to build cars around those engines. Everything is so well designed at a fundamental level." In the words of Oscar Jackson "sometimes stock is best".
OBD II car (like your post 1995 accord) : intake/exhuast/headers won't do tooooo much for what you pay...don't believe the (magazine) hype... they're in the business of selling ads to companies that sell parts....
Turbo: Mmmmm...mixed bag: is it really worth the hassle, $, compatibility problems or engine wear/ potential for destruction? Wouldn't it be better to put that 6k into another (faster) car?
Old Aug 5, 2002 | 04:07 PM
RotaryBzzz's Avatar
Default Re: most bang 4 the $$$$$ (RotaryBzzz)
hey...that's funny...i think i just described MY car (sans the eibach's - i sprung for the APEXi coilovers/shocks)....haha....turbo guys...my *** needs a beatin'...
cheers
Old Aug 5, 2002 | 06:02 PM
Razor's Avatar
probably nitrous is your best bet, 50-60 hp with only 400-500 bucks in parts is well worth it on a stock block.
Old Aug 5, 2002 | 09:01 PM
innate's Avatar
Default Re: most bang 4 the $$$$$ (RJonathan)
if you don't really know what you want to do, i/h/e is what i recommend too. it won't give you the biggest bang for your $ that nitrous will, but it's a decent start.
Old Aug 6, 2002 | 02:20 PM
ichibanjap's Avatar
Not necessarily true, my brother ran a 100 shot on his 95 accord v6 and we never had any problems with the tranny. We could hardly feel the 50 shot, but with the 100 shot it was pretty damn quick.
Old Aug 6, 2002 | 08:33 PM
drvfast's Avatar
work on suspension first u have to be able to handle
Old Aug 6, 2002 | 09:41 PM
denzinz's Avatar
Default Re: most bang 4 the $$$$$ (ichibanjap)
The 95 tranny is far superior then the 98-03 tranny on the V6. Ive had 3 friends with a V6 stock and all has gone through trannies.
Denny
Old Aug 6, 2002 | 09:47 PM
Brandon's Avatar
Life is Suffering
Default Re: most bang 4 the $$$$$ (drvfast)
g's before wee's.
[Modified by F22turbo, 2:50 AM 8/7/2002]
guessohw
Jan 12, 2009 07:39 AM
The7thG
Honda Civic (2001 - 2005)
Feb 4, 2007 08:05 PM
Legendaryyaj
Nov 18, 2003 02:26 PM
Cow
Oct 18, 2002 01:33 AM
myNAteq
Jul 25, 2001 03:14 PM
