98 Coupe with B18b
realized you ment 16 psi as in tire pressure
not bad times buy the way
boost that sucka......
[Modified by 2b_FaSt, 2:51 AM 8/8/2002]
its the only way to get traction, cause i have a lot of torque
lol...nice time..
would a b16a2 be able to run that in a coupe?
thanks,
mike
p.s. what were u launching at??
thanks,
mike
i launch at 2000RPM
I think you should try and launch @ 5k - 6k so your not so far out of the vtec band. If done right, that should help alittle on your 60ft. Also what tires are you running?
What kind of elevation was this at?
That time kinda sucks if you ask me---not unless you are up there in elevation.
I ran a 14.6 in my 2500+ lb. Si hatch with a stock LS motor with the basic i/h/e.
93lscivic...did you have slicks when you ran this time??? I take it you still have a/c and power steering in your hatch...what i/h/e setup did you use??? Did you use the ls tranny??? Would it be hard to get a 92 cx into 13's with a ls n/a???
