50mm Tial Bov Q, spring pressures?
Old Jan 2, 2009 | 11:22 AM
ExVtec's Avatar
Default 50mm Tial Bov Q, spring pressures?
They offer different springs per their bov's.
What do I need to know in order to fit the correct spring?
Thanks in advance
Old Jan 2, 2009 | 11:31 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: 50mm Tial Bov Q, spring pressures?
engine vac at idle.
Old Jan 2, 2009 | 11:53 AM
ExVtec's Avatar
Originally Posted by boostedcivicsir
engine vac at idle.
I don't have a pressure gauge hooked up yet on the car.
Does it need to be exact?
Old Jan 2, 2009 | 11:54 AM
Mr. Badwrench
if not the valve will be a little open at idle thats all.
Old Jan 2, 2009 | 11:55 AM
Mr. Badwrench
we are talking about the q. im not 100 % sure on that. but on the old one thats what the different springs were for.
Old Jan 2, 2009 | 12:04 PM
ExVtec's Avatar
Yea, Q. I figured if I am going to buy one, might as well get the New & Improved..lol.
Old Jan 2, 2009 | 01:39 PM
nonvtecallmotor's Avatar
Most Hondas will use a 7psi spring which should open at around 16" of vac. Most honda pull around 18-22" at idle so that should work well. I had a Tial BOV I think it was an 11psi spring and it opened at 26" of vac and it never opened on the car.
Tial has a chart on there site that give the complete listing.
Old Jan 2, 2009 | 02:00 PM
ExVtec's Avatar
I just spoke with a reliable source that said 11psi should be what I want.
Old Jan 2, 2009 | 02:14 PM
I dont think an 11psi spring will open. Good luck
Old Jan 2, 2009 | 02:54 PM
JDogg's Avatar
it really dosnt matter if the bov is open at idle..
the 7psi spring will open sooner, the 11psi spring will open later. either one will "work"
Old Jan 2, 2009 | 03:49 PM
ExVtec's Avatar
Is it 7 or 11? Anything in between?
Old Jan 2, 2009 | 03:54 PM
miguel329's Avatar
11psi is fine its what ive used on my gsr
90210tegrunner
May 20, 2013 08:33 PM
SAXON
Jul 29, 2010 11:09 AM
got wide
Oct 20, 2008 09:16 AM
JDMCRX
Jun 7, 2007 12:31 PM
JLHDOHC
Aug 2, 2006 05:43 PM
