Skunk2 Intake Manifold acting funny????helllpppp... plzzz
Old Jan 1, 2009 | 10:13 PM
dj theoretic's Avatar
Default Skunk2 Intake Manifold acting funny????helllpppp... plzzz
well I installed a skunk2 Intake Manifold and there have been a few times that I find my self feeling like my car is loosing power around 3000rpm to about 4000rpm... i have to give it gas and it when i pass a point in the RPM's it picks up quicklyyyyy. Not sure what is going on. i have a stock Throttle Body with a No brand 2.5 inch short ram Intake along with a new air filter.
NOTE: engine does not idle. everything works good. I even Cleaned the Intake Control Valve.
Old Jan 1, 2009 | 10:17 PM
The_Honda_Guy's Avatar
Default Re: Skunk2 Intake Manifold acting funny????helllpppp... plzzz
From the sounds of it you may have a vacuum leak. What engine and vehicle? Any CEL's? Sounds like you need to get it to idle first. lol
EDIT: I think you mean IACV (idle air control valve)...
Old Jan 1, 2009 | 10:21 PM
yeah true that!! LOL !!! I'll check out some of the tubes connected to the I.M ...Thanks
94 civic Ex with B16a OBD1..... no problems, no CEL
Old Jan 1, 2009 | 10:24 PM
It's gonna be hard to find a vacuum leak if the car doesn't idle btw. I'd have to guess that you possibly forgot to hook up one of the vacuum lines or forgot to plug a sensor in when changing manifolds. Also, you did use new gaskets on everything right? New injector o-rings?
Old Jan 1, 2009 | 10:41 PM
No I didn't use new injector O rings because they seemed fine to me and looked in good condition, but I did use new gaskets. Everything was hooked right. I think It might be because the I.M is bigger than stock.
Old Jan 1, 2009 | 10:44 PM
Could be one of the reasons you're having idle problems then. The injector o-rings help to seal the intake manifold from vacuum leaks.
Old Jan 1, 2009 | 10:49 PM
Cool, I'll see to that I change them. Thanks for the Help!
Old Jan 1, 2009 | 11:19 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
You may have also gotten connectors mixed up. Make sure your MAP isn't plugged into the TPS and vice versa.
Do you have all injectors plugged into the right clips? All fuel lines tight with correct gaskets? Banjo fitting on the fuel line clocked correctly?
Old Jan 2, 2009 | 07:45 AM
92rotteneg's Avatar
I have the same exhact problem with my car its a ls/vtec with skunk2 intake manifold, dead between 3-4000!
Feb 21, 2011 07:03 PM
DVPTeG
Jun 29, 2007 11:26 AM
stallionsdc2
Jan 23, 2007 07:55 PM
Almost
16
May 5, 2003 06:51 AM
Go Mifune
Aug 16, 2001 01:13 PM
