89 crx si NO spark need help
Old Jan 1, 2009 | 07:32 PM
cwf1988's Avatar
Icon2 89 crx si NO spark need help
ok i want to thank honda tech guys over the years with all my projects. but besides that i have a 1989 crx si and dropped a d15b jdm NON Vtec, yes non vtec ob1 motor in obd0 car. ok i got the wiring harness all on the car pluged up, and i am running a obd0 ecu, i have a jumper harness to run a obd1 ecu but i first tried a obd0 ecu just to get the motor to start up. Ok i am getting fuel and its turning over but i have no spark wat so ever.. i am using a obd1 distriputor and my ??? is why am i not gettting spark at all, its it because the obd0 ecu with a obd1 distributor,, i also though maybe i ran my distributor wires wrong through the pin out, any ideas guys, a pinout of a obd0 harness to obd1 distriputor would be a good help if anyone has one
Old Jan 2, 2009 | 06:23 AM
jlicrx's Avatar
Default Re: 89 crx si NO spark need help
with OBD0 ECU, you must have OBD0 distributor
Old Jan 2, 2009 | 04:01 PM
93formula's Avatar
yup if you have teh jumper harness and obd1 ecu use the obd1 ecu with the obd1 dist....
Old Jan 2, 2009 | 08:11 PM
cwf1988's Avatar
thanks guys,, ill try it out in the morning, and if i have no spark still wat should i look for next,, and wat a bout a resistor box,, ditch it or do i need to use it????
Old Jan 2, 2009 | 08:37 PM
93formula's Avatar
ignitor? but if you correct yoru wiring issues and not mickey mouse it you should not have a problem. also fuses.
Old Jan 3, 2009 | 02:11 AM
gutted's Avatar
- it could be the obd0 ecu because obd1 distributors have a different gear count for the TDC, CYP & CMP sensor so your ecu cant understand it (im pretty sure about this info but dont quote me on it)
- resistor box is dependant on what injectors your running. if your running peak & hold leave the resistor box, if theyre saturated take the box out
- check the coil & igniter in the distributor. its common for them to go out
Pancho2193
Mar 2, 2013 06:35 AM
zeusdavis
14
Mar 28, 2011 08:05 AM
whitecivic11
Mar 28, 2010 11:04 AM
bayron
May 14, 2009 05:39 PM
fin781
Feb 10, 2007 11:32 AM
