b16 cams??
Old Aug 5, 2002 | 06:46 AM
brownshigh's Avatar
Default b16 cams??
are b16a2 cams any better than b16 cams.i figure they probally arent much of a difference but i was guessing since i have a pair of stock 99 si cams lying around.would they they make a diffrence?
Old Aug 5, 2002 | 10:56 AM
bryant's Avatar
Default Re: b16 cams?? (brownshigh)
B16A2 cams compared to what B16 cams. B, A1, A3???
Old Aug 5, 2002 | 12:28 PM
brownshigh's Avatar
Default Re: b16 cams?? (CR-X)
a1
Old Aug 5, 2002 | 12:30 PM
brownshigh's Avatar
oyeah,jus to clarify,i wouldnt be lookin for major gains if any,i jus wanna know if they are diff,thanx
Old Aug 5, 2002 | 02:00 PM
4g4me's Avatar
The newer the cams, the better.
b16a=worst, b16a1/3, better ,b16a2, better, b16b best of the b16 cams
Gsr cams will outperform any b16 non-r cams with a little fuel adjustments.
Same goes for the b18 motors, the newer the better, the JDM spec motors have more aggressive cam profiles.
The best overall cam for a naturally aspirated b16 I have found is to be the 00-01 j-spec ITR cams.
my .02
Old Aug 5, 2002 | 02:05 PM
riceboy's Avatar
Default Re: b16 cams?? (4g4me)
my .02
where did you get your information?
There are no differences in B16A cams be it B16A1, B16A2 or B16A3, they are all the same lift and duration, the only ones that differ are the Type-R cams. The only way that the newer cams could be better is that if you have had the valve lash set horrible for a long time and it has worn the lobes.
Old Aug 5, 2002 | 04:34 PM
Xsi's Avatar
Xsi
Default Re: b16 cams?? (riceboy)
my .02
No, the b16A cams are less aggressive than b16a2 cams, this, along with larger TB and higher CR is why the b16a2 has 10 more HP.
Automatic b16a cams are the worst of the lot.
Old Aug 5, 2002 | 05:57 PM
brownshigh's Avatar
Default Re: b16 cams?? (Xsi)
yea,wut he said i thought that was true.thanx fellashave
Old Aug 5, 2002 | 07:01 PM
Francois's Avatar
Also,the vtec point on the newer B16 are higher,5500,compare to 4800-5000 rpm for the first gen.
So there are maybe a little difference between these cams.
Maybe that as something to do with the more stringent OB2?
Old Aug 5, 2002 | 07:16 PM
Xsi's Avatar
Xsi
Default Re: b16 cams?? (Francois)
Ok, just checked it out, the b16a2 intake cam has 0.5mm higher lift (10.6 over 10.1mm), the exhaust has 0.4mm more (9.4 over 9.0). The duration is the same.
stockb18c
Oct 25, 2006 03:51 PM
91b16civic
May 13, 2003 04:26 AM
g2style
Feb 3, 2003 01:26 PM
PYITR821
Jun 9, 2002 01:07 PM
