paint came out webby
Old Jan 1, 2009 | 11:36 AM
91(si)hatchey's Avatar
Default paint came out webby
hey so i was painting my car with duplicolor paint. the filter is like a one time use one from harbor freight and ive used it twice. so i tried spraying some basecoat and it came out webby. what happened? my guess its the filter
Old Jan 1, 2009 | 11:59 AM
FearTheH's Avatar
Default Re: paint came out webby
Buy a good air dryer/filter. It'll be a lot cheaper in the long run. You probably got moisture in the line. Your gun adjustments could be off, nozzle could be obstructed. Are you cleaning your gun with lacquer thinner after each use? Make sure the nozzle and pins are clean, if its gravity fed pour lacquer thinner in the cup and run it through the gun, then disassemble it and clean thoroughly. Did the base come out webby or the clear? Pictures???
Old Jan 1, 2009 | 12:48 PM
i clean the gun with mineral spirits every time. its a husky hvlp. ive only done the basecoat. it must b the filter
Old Jan 1, 2009 | 01:24 PM
Wakes4Fun's Avatar
You talking about the air line filter or the actual paint filter in the gun itself? I just use 2 of the air inline filters every time I spray and they usually seem to keep the moisture down alot. That and I make sure to always drain my compressor well before painting anything.
Old Jan 1, 2009 | 02:38 PM
bigD's Avatar
if your using the lacquer based duplicolor you cant use mineral spirits, need to clean your gun with lacquer thinner. I would bet thats your problem.
Old Jan 2, 2009 | 10:36 AM
FearTheH's Avatar
Yes! Lacquer thinner cleans everything! Use it!
Old Jan 2, 2009 | 12:47 PM
precisionsc54's Avatar
haha you dont want to be using mineral spirits with that type of paint. It doesnt mix. Go to a paint store and buy quality paint and reducer.
Old Jan 2, 2009 | 02:31 PM
well i dont want to buy new paint. and its been spraying good the whole, what type of lacquer should i use. would i use that to clean to the car before painting
Old Jan 2, 2009 | 02:52 PM
FearTheH's Avatar
He didn't say he was reducing the paint with mineral spirits, he's cleaning the gun with it, which can still have bad effects. Also make sure all of your mixing ratios are being used correctly.
Old Jan 2, 2009 | 04:16 PM
bigD's Avatar
If he is cleaning the gun with it most likely there is still some in there when he adds paint, I would aslo bet he wiped the car down with it also. The paint hes using comes premixed but you can add lacquer thinner if your having problems spraying it. You really should wipe the car down with a good automotive wax and grease remover.
Old Jan 2, 2009 | 04:17 PM
well mineral spirits and Urethane paint thinner do not mix well. They are both diff chemical compositions & weights and will seperate. Clean your gun with cheap urethane paint thinner or gun wash. Dont use mineral spirits period.
Old Jan 2, 2009 | 04:52 PM
bigD's Avatar
sorry but paint thinner and mineral spirits are pretty much the same thing, you cant use either one with lacquer.
Old Jan 2, 2009 | 05:07 PM
When I say paint thinner im referring to urethane reducer. I never use mineral spirits for anything
Old Jan 2, 2009 | 07:38 PM
j_bizach's Avatar
did it wrinkle?
Old Jan 5, 2009 | 08:57 AM
alright thanks a lot guys, ya this is my first experience with painting. i picked up some laquer thinner so ill start using that. so before i put on a coat i need to use that wax and grease remover?
Old Jan 5, 2009 | 09:28 AM
LoSt is BlaCk's Avatar
hey judging by your location you are in my area...did you do the body work also? I wanna see how this car comes out, i've been trying to keep up with your posts on this project...
Old Jan 5, 2009 | 09:31 AM
i didn't do any body work. its almost been pretty straight besides a bump on the hood and weather stripping. ive only painted it. ill post some pics today.
Old Jan 5, 2009 | 06:55 PM
AZSupraT's Avatar
I layed down some primer last week on my Supra 1:1 Duplicolor primer and Duplicolor Reducer... with an inline filter.. Half of it came out webby/dry/think like this... I think I need more reducer? I messed with the settings on the gun alot and it all stayed the same...
I sanded it all down though and I got it to be nice and smooth just like it should look... but is it sticking the same?
Old Jan 5, 2009 | 09:25 PM
no if its spraying kinda dry its def not goig to stick the same.
thenext
Aug 6, 2011 10:21 AM
LudeChild
Dec 6, 2004 07:30 PM
CivicNA
Aug 24, 2003 09:14 PM
