Where is block drain bolt on H22a?
Old Jan 1, 2009 | 09:33 AM
JJexpress's Avatar
Default Where is block drain bolt on H22a?
Where exactly around the oil filter is the coolant drain bolt on the block of a H22a? Is it right beside the oil pressure switch under the oil filter? There is a big leak and it's pretty messy. I don't know if its oil or coolant. And there is a hole that looks like its missing a screw that may be the coolant drain plug... It's slightly under the oil filter and beside the oil pressure switch. There is another bolt above the oil filter in the corner that looks like it may be it but it's very difficult to get too.... Which one is it??? Thank you!! and Happy new years!
Old Jan 1, 2009 | 09:41 AM
E-Money's Avatar
Default Re: Where is block drain bolt on H22a?
The coolant drain can be a real PITA to get off while your on your back. I would only drain it for a overhaul.
Old Jan 1, 2009 | 09:59 AM
JJexpress's Avatar
Please look at this pic. Could the leak be due to the missing screw? Is that the coolant drain bolt?
Old Jan 1, 2009 | 10:09 AM
jlude90's Avatar
no, thats just a mounting point for something, i don't remember what. probably the block heater or something, but its just a threaded hole, doesn't go all the way through the block, and doesn't hit a coolant or oil passage, i just checked
so thats not your problem
Old Jan 1, 2009 | 10:31 AM
JJexpress's Avatar
Thank you for your help jlude90! Happy new years!
Old Jan 1, 2009 | 10:37 PM
DOHCMonster410's Avatar
find out if it is oil or coolant. if it is oil, i had a similar sounding problem recently. take off the oil filter and undo the bolt in the center and take out the spout. iirc the socket size i used was 1 1/4". check the back of tht oil cooler or w.e it is and there should be an o ring. mine recently blew out and i leaked a truck ton of oil
turbodcxbro
16
Nov 2, 2012 01:31 AM
usdmftw
Nov 29, 2010 05:29 PM
missionaryrider
Jan 15, 2010 08:23 AM
boostmee
Aug 18, 2008 02:05 PM
brcivic411
Feb 1, 2003 12:09 PM
