cluster temp guage
The wiring diagram isn't clear exactly which wire carries the signal, I don't think it's as simple as one wire per signal. But I'm really not sure, I've never done that swap.
correct me if im wrong but there should be a wire that goes straight to the guage. if you look the under the distributor there is one wire a female plug that should go to the gauge. I would use a fluke meter have one lead on that female plug and take the other lead behind the guage and touch a few pins until you find continuity, make sure your car is off.
joecivic93
Jan 6, 2004 10:07 PM
xXx Justin xXx
Jun 13, 2002 07:20 PM
