Horn Relay Question '94 Civic...Horn not working!
Old Dec 31, 2008 | 03:47 PM
weavertime1's Avatar
Default Horn Relay Question '94 Civic...Horn not working!
I recently picked up a beat '94 civic ex coupe and replaced and cleaned pretty much every part on the whole car. Two days ago someone stopped by the garage and asked if I would sell it. Since fixing it to sell it was my original intention I said yes, but I told the guy it needed an alignment, a driver side inner fender installed, and a working horn. We agreed I'd fix it, so I aligned it today, installed the inner fender liner, and screwed with the horn for like 2 hours. Long story short...the horn works properly as I tested it on a parts car I had laying around. The fuse and all of the wiring is fine, so I wondered if anyone knew for sure where the horn relay is located on this car. Also, if you have had a similar issue and figured it out, throw any info my way. I don't sell cars that need work, not even little stuff like a horn, because I believe karma will catch up to you sooner or later. Thanks in advance for any help you can give!
Old Dec 31, 2008 | 04:41 PM
z6hatchboy's Avatar
Default Re: Horn Relay Question '94 Civic...Horn not working!
its either in the under-hood relay box or under the dash, not sure which one though
Old Dec 31, 2008 | 09:10 PM
CivicSpoon's Avatar
Yup, under dash:
bigboi407
12
Mar 29, 2015 03:16 PM
jayzeno
Aug 21, 2011 07:30 PM
erikiksaz1
Audio / Security / Video
Jun 29, 2009 05:59 PM
tei344
Nov 9, 2007 05:51 AM
Stuntbug
Mar 14, 2005 04:01 PM
