Advice PLEASE
Old Dec 30, 2008 | 11:24 PM
jrod95cpe's Avatar
Default Advice PLEASE
whats up HT, so heres the deal, im rollin around with an auto tranny right now, WHACK. I wanna swap to manual, my question is, is it worth it to just drop 1G and have a local shop do it and keep my stock motor, OR buy a JDM D15B with manaul ttranny and do it myself. This car is my daily so it has to pass smog and easily be repaired ya know. any help appreciated
Old Dec 30, 2008 | 11:45 PM
Syndacate's Avatar
Default Re: Advice PLEASE
I say do the trans swap yourself. You didn't specify what kind of car you had, but the D15B doesn't really offer more power than the Z6 - it will be more powerful than the B7 if you have a DX (your sig says 95 coupe, so I'm guessing it's an EX or an DX) - but not really a lot, you'll be happy for like a week, then just pissed that you spent all that money on it and want more. Though the B7 + the auto trans makes things weak, I say go for the 5sp and spice things up a bit.
Get a Z6 manual trans too, over the B7/B8/Z1, it offers shorter gearing.
I also say screw letting a shop do it, do it yourself. It's not too hard, just un-do the side and the rear trans mount, unbolt the starter/trans. You'll need the clutch/flywheel from a 5th gen ('92-'95) manual D series transmission, the transmission itself, master & slave cylinders, 3rd pedal or manual pedal assembly, clutch lines, shift linkage, shifter, and a manual ECU. Unless I missed something everything else is the same - and if you've never done it but are remotely technically inclined you can do it in a weekend, maximum.
Some people say drop the engine to remove the trans, I say don't, it's not needed, just a waste of time. Maybe it's different if you have a hoist, I don't. Simply jack it up and remove the trans that way, though getting it back up is a bit of a trick, I suggest removing wheels / bumper, it's easier then, it's also easier if you have power tools, but gotta use what you got.
Good luck, I say swap the trans is your best bet.
Old Dec 30, 2008 | 11:48 PM
jrod95cpe's Avatar
thanks for the input yeah i have a 95 DX i also have a Z6 head to go on their when i swap to manual. i also have the linkage and shifter and as soon as my friend comes up on a EX tranny from an ek he"s just gonna give me his DX tranny haha
jdm.coupe3234
19
May 12, 2010 09:50 PM
Civik Sutra
Nov 7, 2005 08:03 AM
crimsonafterlife
Nov 6, 2005 01:58 PM
logikalfury
Aug 17, 2005 10:00 PM
cybrbyt
10
Mar 16, 2004 05:15 PM
