OBD2 WaterPump on OBD1 Block? -B18C
Old Dec 30, 2008 | 03:42 PM
OMG THE GOGGLES's Avatar
Default OBD2 WaterPump on OBD1 Block? -B18C
Just want to know if using an OBD2 waterpump, on an OBD1 block will work. I would use the search feature but it blows on the new honda-tech and I got all unrelated search results.
Block 1995 B18C1
Waterpump 96-01 Integra 19200-p72-013
Car has an OBD2 Wiring harness.
Not sure as to why they are different part numbers from OBD2 to OBD1, I know the difference with the oil pumps such as a crank angle sensor being there or not, but was unsure why the waterpumps would be different.
Thank you very much
Old Dec 30, 2008 | 04:20 PM
Turbo B18C EJ6's Avatar
Default Re: OBD2 WaterPump on OBD1 Block? -B18C
yes you can run a obd2 water pump on your obd1 motor. all b series vtec water pumps are the same.
Old Dec 31, 2008 | 03:17 PM
Thank you
Zinch
Mar 4, 2007 05:08 PM
JMcDB18C
May 22, 2005 09:07 PM
whoa its len 2
Oct 2, 2004 07:18 AM
Civic
Dec 14, 2003 11:51 AM
