ctr 4 lug conversion
What exactly does it consist of?
I need new rotors and breaks, but i dont want to spend the money on that when they arent going to fit the conversion.
I've been told about adaptors idk if i want to do that!
need some help asap!!!
Cool Cool Island Breezes. BOY-EE
CTR 4 lug? Surely, you jest.
The CTR 5 lug consists of knuckles, hubs, brakes (F), and hubs/brakes (R).
Usually, they are sold as a complete knuckle assembly (F) and trailing arm assembly (R).
You also need 5 lug wheels (duh).
You can use USDM ITR 5 lug rotors and pads. Don't buy anything for your 4 lug setup if you're getting a CTR setup. It's all different.
If you put a CTR setup on a DC or 92-95 civic, you will need an alignment THAT DAY.
ok it might be an itr conversion...im not sure. what i am sure of is that the measurements i need are 4x114. Do you know of a good price range to go off of?
i know the rims that come in that size are type r's and they look like the hx rims that ppl always confuse them with!
You can use prelude or accord or CRV outer joints mated to your USDM axles.
If you use a CTR conversion on a 92-95 civic or 94-01 integra, you will need an alignment badly.
If you use an ITR 5 lug conversion on a 96-00 civic, you will need an alignment badly.
Uneekpinoysk8er
Nov 21, 2004 06:54 PM
