Knife-edging crankshaft and micropolishing?
Old Aug 4, 2002 | 10:31 PM
Norcalstoppy's Avatar
Default Knife-edging crankshaft and micropolishing?
Where can I get this done?
Jay Kim
Old Aug 4, 2002 | 11:31 PM
00civicvtec's Avatar
Default Re: Knife-edging crankshaft and micropolishing? (AllMotorMonster)
Any automotive machine shop can do micropolishing (mine quoted $35), not sure about knife-edging...
Old Aug 6, 2002 | 01:01 AM
no one? ttt
Old Aug 6, 2002 | 03:08 AM
rice a rona's Avatar
Bensons machine is OG at that.
Old Aug 6, 2002 | 10:08 AM
l's Avatar
l
i used to always plan to do alot of crank work... however, recently i heard stock cranks can go a long long long long long long way in terms of speed
Old Aug 6, 2002 | 10:21 AM
Hayasa15's Avatar
Default Re: Knife-edging crankshaft and micropolishing? (IM ALL SHO)
what are the benefits of knife-edging and micropolishing?
Old Aug 6, 2002 | 10:24 AM
IlikeTODA's Avatar
Default Re: Knife-edging crankshaft and micropolishing? (Hayasa15)
I have heard that there is no gain in performance if you knife edge a Honda crank since they don't go throw the oil like on some domestics. I still see people spend the money and get it done for some reason. It is less rotating mass, but why not just get a lightened flywheel?
Thanks, J
Old Aug 6, 2002 | 10:25 AM
Spade's Avatar
Default Re: Knife-edging crankshaft and micropolishing? (IlikeTODA)
The only thing you should do to a honda crank shaft is balance and micro-polish.
Old Aug 6, 2002 | 10:27 AM
MikeSarr_GSR's Avatar
Default Re: Knife-edging crankshaft and micropolishing? (Spade)
I have read opinions of people way smarter than me that say knifing
a crank makes it less structurally sound.
Old Aug 6, 2002 | 10:31 AM
X2BOARD's Avatar
Default Re: Knife-edging crankshaft and micropolishing? (MikeSarr_GSR)
Yes, it does become less structurally sound... but most people that do this are full race... I wouldn't have it done on a street car.
Micro polishing just gives the journals a smoother surface for the bearings to contact... less bearing wear.
Most machine shops do both of these procedures.
X2
Old Aug 6, 2002 | 10:38 AM
l's Avatar
l
honda cranks are balanced from the factory
Old Aug 6, 2002 | 10:39 AM
Spade's Avatar
Yeah and so are the pistons but they are still off.
Old Aug 6, 2002 | 10:50 AM
l's Avatar
l
pistons are different... they dont come in a 4 pack so you could be purchasing pistons made a year or so apart... either way... balancing pistons and rods is a good idea
Old Aug 6, 2002 | 11:02 AM
Spade's Avatar
And don't forget the comfort of knowing the crank is balanced.
You can always have them check it and see if it needs it.
DarKStaR5
Nov 8, 2007 07:06 PM
BABY NSX
11
Oct 25, 2006 04:29 AM
HackeN
Aug 24, 2006 01:53 PM
Boostless97Lude
Jul 30, 2002 04:25 PM
TheSwift1
May 29, 2002 10:42 AM
