ls/ v tec???
Old Dec 30, 2008 | 09:58 AM
00eddie00(95eg)'s Avatar
Icon7 ls/ v tec???
hey guys im thinking of doing a ls vtec set up and wondering what would be the best way about doing it so that the hybrid lasts a long time. my car is bared for a b18 so thats why im doing it....more power baby..... let me know and thank you in advance......if your gonna trash talk me then just leave thanks.
Old Dec 30, 2008 | 10:47 AM
JDM_VTI_Hatch's Avatar
Default Re: ls/ v tec???
The biggest problem with the LS VTEC (as far as i know) is the oil galley's dont line up perfectly starving the head of much needed oil. Just make sure the Galley is machined properly to allow oil to flow easily. A proper set of ARP head studs and a nice head gasket to finish of the job. And make sure you have it tuned too, otherwise you wont get what you want out of it, use this. http://www.tunewithcrome.com/
Old Dec 30, 2008 | 01:32 PM
thumper64's Avatar
I've read of some people balancing their cranks and adding a girdle. Anything to mimic the B18C1 or C5 would be good.
Old Dec 30, 2008 | 03:38 PM
1990hf's Avatar
i got an ls v-tec and it pull really strong. i heard b16 head is the better way to go cause it got better air flow. if you're interested i got a brand new set ARP head stud for sale. its for Ls v-tec or B20 v-tec conversion.
Old Dec 30, 2008 | 03:40 PM
1990hf's Avatar
Sorry wrong picture
Old Jan 6, 2009 | 03:06 PM
GSREXMan's Avatar
Well if you doing the LS V you mait want to go with the B16 head many people say that the B16 head is close to the Type R head but i am not shure
Old Jan 6, 2009 | 03:08 PM
nix94delsol's Avatar
As far as flow, it is, other than that they're a lot different.
Old Jan 6, 2009 | 03:28 PM
-=ZAK=-'s Avatar
man i want to do a ls vtec myself but im scared to cause when i mention it smeone is always refering it to a ticking time bomb fast why it runs but almost guaranteed to go out eventually =/
Old Jan 6, 2009 | 03:47 PM
anything built shitty is going to be a "Time bomb" do it right and youll be fine.
Old Jan 6, 2009 | 04:16 PM
Stock90Civic's Avatar
The main problem people have with the set ups not lasting is that they slap on a head thats made to rev and the block still is not made for it. In the All Motor forum there is a great 40+ page write up talking about it.
Old Jan 6, 2009 | 04:30 PM
srmofo's Avatar
if properly/correctly done, they will last
Old Jan 6, 2009 | 04:41 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
mine lasted for 4 yrs and still going......built right no problems. there's lots and lots of info about LSvtec on here.
Old Jan 6, 2009 | 04:45 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
http://www.c-speedracing.com/howto/lsvtec/lsvtec.php
Old Jan 6, 2009 | 08:28 PM
Toy Civic's Avatar
I have been through the BAR process and know some tricks and tips that may help you.
Before I give some detailed answers, look at your BAR sticker carefully. Next to "Eng.yr/make/size" it should say "19xx/Acura/1.8L". What I need to know is if there is anything printed in the "Comments" line??? Is it blank? If so, then you have a ton of options. If it says anything about Acura Integra LS, then you are in a pickle.
Reply back and I will provide more info.
Old Jan 6, 2009 | 09:52 PM
dividedas1's Avatar
so true. you need to have it tuned to what the block can withstand. just because the b16 head can see 8400 doesn't mean the block can handle it unless built for it. plus stock block you probably aren't making too much more power up there anyways.
NOTDISFA5
Aug 8, 2010 08:02 PM
christian7750
30
Apr 4, 2009 04:39 AM
master honda tech
Apr 3, 2005 09:33 PM
Chuji
14
May 18, 2004 05:03 AM
