Need a drag radial that lasts longer than BFGs
Old Dec 30, 2008 | 03:28 AM
Legion_2's Avatar
Default Need a drag radial that lasts longer than BFGs
My BFG 225/50/15s only lasted 4,000 miles. That's with proper alignment, proper inflation, and I never did a single (intentional) burnout.
I really can't afford to buy another set if it's only going to last a few months. So what's the next step down? I'm willing to sacrifice traction for something that lasts longer. Do Azenis RTs last longer?
Old Dec 30, 2008 | 04:48 AM
bigdgsr's Avatar
Default Re: Need a drag radial that lasts longer than BFGs
How much power are you making? Do you daily drive the car? When my car was 400whp I ran the BFG 205/50/15s for about 5k miles. I wouldn't get any traction until the top of 3rd gear. Last year switched to MT 205/50/15s and it was a night and day difference. The car was hooking 2nd gear. Right now I have about 2k miles on the MT's and they still look new.
You have to remember that drag radials are not going to last forever. Most of them do not even have a treadwear rating. I would say that 4 to 5k miles is what you will probably get out of them. If you want traction, stick with drag radials, if you don't then buy something cheaper like all-seaons.
Old Dec 30, 2008 | 09:32 AM
418whpturboD's Avatar
i ran the nitto 555r drag radials for 2 years and one was daily driving on them and the still have tons of tread but they dont hook very well at the track compared to bfgs..
Old Jan 1, 2009 | 05:39 PM
Legion_2's Avatar
I would LIKE to try the Nittos, but apparently they don't make them for 15" rims. And as far as the MTs - are you referring to the ET streets? I figured those would get eaten up the quickest of all, seeing as they're basically cheater slicks. I'll have to check them out more.
Old Jan 1, 2009 | 05:47 PM
Bailhatch's Avatar
Azenis probably won't last any longer for you. They are no drag tire, but will make cornering waaay more fun than DRs on the front.
Old Jan 1, 2009 | 08:46 PM
91TurboGSRCRX's Avatar
I hate my BFGs 225 50 15 .I only got 1500miles out of them ,I plan on going back to a street tire and i was thinking of the Azenis r615,Sence i see no need to even run a DRs on the street sence (damn things dont even help)
Old Jan 1, 2009 | 11:16 PM
Garage 808 Hatch's Avatar
The azenis on my eg lasted 15000 miles, and then i sold the car. the new owner put another 4 months on them after that
Old Jan 2, 2009 | 02:50 AM
Bailhatch's Avatar
15,000? unreal. I get about 3000 out of the fronts and 10000 out of the rears. Thats with about 330whp. 3rd hooks 100% and 2nd about 80% and I rev out 1-2-3 every day...plus lots of hard cornering.
Old Jan 2, 2009 | 08:29 AM
ral24_hct's Avatar
I use toyo R888 and they last abut a year daely drive and hook ok I chage from 205/50/15 to 235/40/17 for more traction my civic is 424 whp
Old Jan 4, 2009 | 07:17 PM
Legion_2's Avatar
Torn between Toyo RA-1 and the BFG drags after these conclusions:
M/T ET Streets: no sidewall, don't last long enough
Nitto NT555R: aren't made for 15" rims
Falken Azenis RT-615: sidewall is too stiff (won't go with my General Exclaim UHPs in the rear)
Toyo R888: too expensive and have a stiffer sidewall than the RA-1
Toyo RA-1: roughly same price as the BFG drags, more sidewall than the drags, more tread depth
Looking into the RA-1s more. Any other R-comp tires I should look into?
Old Jan 4, 2009 | 07:42 PM
narfdanarf's Avatar
I'm on my last set of bfg drag radials. I'm really tired of buying tires 3 times/ year for only moderately better traction than even my all weather tires.
Old Jan 4, 2009 | 09:06 PM
blinx9900's Avatar
I like my nt01's, i get good life out of them, but my car only weighs 2260lbs...
Old Feb 18, 2009 | 07:11 PM
Legion_2's Avatar
So I went with Azenis RT-615s and they just really blow the BFGs out of the water. The Falkens are a smaller tire (205/50 vs. 225/50) but they have BETTER traction. I spun the BFGs all day long in 2nd and I honestly can't even spin 2nd with the Falkens. I just got them installed 2 hours ago and I've been tearing up the city. The tires are just amazing.
BFGs:
-Insanely loud on the freeway
-Insanely sloppy/unresponsive/dangerous handling
-Rubbed the **** out of my framerail
-Adequate traction
-$300/shipped for a pair from Tirerack
Falkens:
-Whisper quiet
-Amazing handling (no more accidentally veering into neighboring lanes on the freeway...)
-Perfect fit w/ no rubbing issues
-Slightly better traction than the aged BFGs, although brand-new BFGs might have the slight advantage.
-$180/shipped for a pair from Vulcan tire
Falkens FTW. I'll never buy the BFGs again.
B18C Turbo
Oct 25, 2006 08:57 AM
NathanMorris
Jun 6, 2006 06:30 AM
CETVTOGEM
Aug 12, 2005 12:31 AM
Teg4e
Jan 25, 2005 08:55 AM
HT Chaplain
Oct 20, 2004 05:34 PM
