Turbo SOHC ZC Question?
My group of friends and myself have a couple questions. We are building an Auto-X car, and have a SOHC ZC and a Turbo kit. But, we don't have any injectors or EMU. And we are kind of on a tight budget, so we are going to try and use the stock injectors and the stock ecu.
I was wondering which amount of boost will be safe to run, on a basemap. We are going to try and get a piggyback system, or should we go all the way with EMU. Need some advice on that.
Turbo Specs follow.
Compressor Specs:
3” Compressor Intel
Compressor : .50 A.R.
Compressor : 57 Trim
M23/T4 Compressor Housing
3” or 76.20mm Major
1.988” or 50.50mm Minor
Turbine Specs:
T3 Type Turbine
2.25” Exducer
Turbine : .64 A.R.
Turbine : 76 Trim
2.56” or 65.04mm Major
2.204” or 56.00mm Minor
5 bolts design for exhaust outlet flange
..... I can get any other info thats needed.
Turbo Specs follow.
Compressor Specs:
3” Compressor Intel
3” or 76.20mm Major
Turbine Specs:
T3 Type Turbine
2.25” Exducer
Turbine : .64 A.R.
Turbine : 76 Trim
HatchbackCivicPR
May 18, 2006 10:06 AM
