idle problem
Old Dec 29, 2008 | 06:03 PM
-=ZAK=-'s Avatar
Default idle problem
i did a ls swap into my hatch and im having an idle problem it idles around 1.8grand the idle control screw is completely removed so it wont go any lower. the o2 sensor isnt plugged in but i dont think that would cause it to idle so high would it(hope its not this the o2 plug cost 114$)? could be high timing i dont really want to mess with that to much but i will if i have to. if i let my car set for a while it will idle to 2grand and roll so i goes baaaaa bahm baaaaa bahm and that dont sound cool when your going through town and everyone is like is this guy an idiot? any ideas of what my problems could be
Old Dec 29, 2008 | 06:36 PM
zeplin's Avatar
Default Re: idle problem
Try cleaning your IACV with carb cleaner. If that doesn't fix it I'd install the idle screw and adjust it. I don't think the O2 sensor controls idle at all (I could be wrong).
Old Dec 29, 2008 | 06:42 PM
-=ZAK=-'s Avatar
alright that sounds about right i looked on the team integra site and theres a post about the iacv and cleaning it. ill try first thing in the morning and post results
Old Dec 29, 2008 | 08:12 PM
}honda=life{'s Avatar
first just put the idle screw back in ..... screwing it in will bring the idle down and screwing it out with bring it up... and see where it idles then ... and let me know... if iacv was bad it will surge alot.... but in some situations i have seen it idle the car high but not in very many it would be like the gasket leaking or the iacv cracked....
Old Dec 30, 2008 | 06:46 AM
-=ZAK=-'s Avatar
took out the iacv and cleaned it big thumbs up it fixed the problem instantly kudos the zeplin
Old Dec 30, 2008 | 06:48 AM
-=ZAK=-'s Avatar
i think you got that bass akwards screwing it out lowers.....in raises?? or on mine atleast.
Aguem2
Aug 10, 2013 10:05 AM
GreenMachineRex
Sep 22, 2005 03:12 PM
SpoolnG2
Jan 8, 2003 09:13 AM
sushibug
May 1, 2002 12:35 PM
