bog hard at 4k HELP!!!
Old Dec 29, 2008 | 05:36 PM
96accordsir's Avatar
Default bog hard at 4k HELP!!!
i got an lsvtec in my ef and i just got new plugs and got it running on all cylinders. it seemed a little rough at idle till i got my new bkr7e's. it is a little sluggish then at like 3k-4k the engine continues to accelerate smooth with my foot but the car stops accelerating. i already got new pump and filter. etc. it also runs rich as hell with a stock p28.
update: wow i got the timing right and now my car wont start at all. i also put on a new intake manifold. wtf!!
Old Dec 29, 2008 | 05:42 PM
Ahknodd's Avatar
Default Re: bog hard at 4k HELP!!!
Any codes?
When did this start happening?
Any odd vibrations or sounds?
How do you know it's running too rich? Bad mpg, black exhaust,etc?
Need a little more info. My thought would be check fuel pressure, timing, and your codes.
Old Dec 29, 2008 | 05:56 PM
carnz98gsr's Avatar
sounds like its in limp mode. my gsr would feel like i hit a wall at ~4000 when i was in limp mode
Old Dec 29, 2008 | 06:28 PM
Originally Posted by Ahknodd
Any codes?
no codes
its happened since i got it on all cylinders
the motor is a little shakey sometimes at idle and it has a loose valve sound and tapping
spark plugs were black and smell
Old Dec 29, 2008 | 06:51 PM
Ahknodd's Avatar
Are all the plugs looking the same? Did you recently swap the motor, then have the trouble with it not hitting on all cylinders?
So what all is new, I see the plugs, wires, fuel pump, and fuel filter, anything else you've done?
I would recommend, resetting your ecu, then testing fuel pressure, and spark timing.
Good luck, let us know what you find.
Old Dec 29, 2008 | 07:07 PM
EFRue57's Avatar
check your timing if you haven't already.
Old Dec 29, 2008 | 07:39 PM
it just wasnt on all cylinders because a sticky injector and i re wired it cause i had like 5 cel codes. i got alot new. dizzy, wires, plugs, injectors, wiring was redone, ecu, pump, filter.
just now it wasnt starting and i have a LS fpr and switched it to b16 and it fired right up, but still bogs the same.
how do i reset my ecu and test those things properly??
thnx
Old Dec 29, 2008 | 08:35 PM
Ahknodd's Avatar
Best way to reset your ecu is to pull the Hazard fuse in the under hood fuse box. It's either a 15A or a 20A fuse. Leave it out for about 30 seconds then plug her in and your ecu is reset. Start her up and check that you don't have any codes.
To check your timing you'll need a timing light. Pretty strait forward, hook up the timing light on the battery pos and neg terminals and the inductive lead on the number 1 spark plug wire and look at your crank pulley. You should see the three timing marks on the pulley line up with the tabs on your timing belt cover. You want it to line up with the middle mark on the crank pulley, but if it's on the first or third you're only 2 degrees off. To adjust your timing you simply unbolt your dizzy just enough so you can turn it. With the car on and the timing light in had have a friend (or if you've got long arms, I don't so I need help) turn the dizzy until you line up the timing marks with the tabs. Only do this if it's off of course.
To check fuel pressure you'll need a fuel pressure tester. If you don't have access to one maybe you have a friend or relative or if you know a shop you go to have them test it for you. No way to do it with out the right tools.
That's where I would start.
Old Dec 30, 2008 | 02:39 PM
i have the timing on the crank on the mark on its own not the set of three?
Old Dec 30, 2008 | 02:51 PM
i think i have a sticky valve in cylinder 4 because no matter what i do or get new the plug is always carbon fouled fast.
Old Dec 30, 2008 | 08:09 PM
Ahknodd's Avatar
The mark that is all by it's self is the TDC mark. That means your spark plugs are firing at TDC and that's WAY too late! You want to be about 18 degrees BEFORE TDC. Time it right and see what happens. You may be a tooth off on the timing belt if you can't get it to time right. Do you have an adjustable cam gear?
Fix your timing first, you'll be going around in circles if you don't have a properly timed car.
Old Jan 1, 2009 | 05:05 AM
k ill try it in the middle of the three tomorrow... im drunk tonight!
Old Jan 1, 2009 | 10:34 AM
Ahknodd's Avatar
^^^ amen brother! Happy New Year!
Old Jan 1, 2009 | 02:34 PM
wtf does that mean. i dont remember typing that. middle of three tomorrow????
Old Jan 1, 2009 | 06:41 PM
Ahknodd's Avatar
I think you're gunna try to time your car and put it on the middle timing mark of the three marks on your pulley. Drunkeness will do that to a man. lol
Old Jan 3, 2009 | 12:30 AM
o i did make sense lol
Old Jan 8, 2009 | 04:30 PM
Old Jun 9, 2009 | 11:34 PM
bump
soon2befasst
Feb 1, 2011 09:58 AM
taimysho0
12
Jan 15, 2010 10:43 PM
vtecsi00
Mar 5, 2008 12:35 PM
RudeLude
May 3, 2005 10:32 AM
Sohc Driver
Sep 21, 2003 11:07 AM
