Help with cel codes
Old Dec 29, 2008 | 04:26 PM
suzuki1211's Avatar
Default Help with cel codes
Have a 98 civic lx with automatic. The CEL is showing four codes: 17-vss speed sensor, 20-electrical load detector, 41-primary oxygen sensor heater and 65-secondary oxygen sensor heater wire. Just replaced the alternater which took care of some other problems but when I hooked the battery back up on the car, the CEL tripped these four codes (17,20,41,65) The only symptoms showing with the car now is the speedometer does not work.
Old Dec 29, 2008 | 05:43 PM
doc's Avatar
doc
Default Re: Help with cel codes
You should check the fuses. VSS Sensor and the O2 Heater share the same fuse.
I'm not sure if i have the right wireing schmatic here, but check the Fuse 15 in the under dash fuse box.
Old Dec 30, 2008 | 11:33 AM
suzuki1211's Avatar
Dude you are the best, it was a blown fuse. Thanks for the suggestion.
mikeycivic
Sep 21, 2011 03:57 AM
Civic Racer X 7
13
Jun 1, 2011 04:56 AM
dices543
Oct 1, 2010 11:10 AM
jrami020
Oct 18, 2009 02:24 PM
rebuiltSI
Jul 24, 2007 09:07 PM
