open headers...
Old Aug 4, 2002 | 07:27 PM
91HATCH's Avatar
Default open headers...will it help for 1/4 mile?
open headers...will it help at the track or not? on a b16a
[Modified by 91HATCH, 6:19 AM 8/6/2002]
Old Aug 4, 2002 | 07:29 PM
DJ KrunchyKracker's Avatar
Default Re: open headers... (91HATCH)
it will help be loud. but thats about it. u will lose all of the torque. and u dont have much to spare as it is. but u might as well test it for yourself and find out.
Old Aug 4, 2002 | 08:38 PM
Mugen Dom's Avatar
Default Re: open headers... (TheRZA28)
uhhh i think ur wrong there u gain hp and torque with open header from wut i saw on the SCC (sport cmpact car) tested their b16 EG
Old Aug 4, 2002 | 08:50 PM
Trevor's Avatar
Default Re: open headers... (jdmb18hatch)
Check out this auction on ebay, for your open exhaust...
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1848366905
Old Aug 4, 2002 | 09:00 PM
civicmark's Avatar
well, if unbolting you cat, makes you lose hp(unless you're going FI), wouldnt unbolding your headers lose it too? + it'll be louder than those 8 bangers hehe
Old Aug 4, 2002 | 09:01 PM
Mugen Dom's Avatar
Default Re: open headers... (civicmark)
no not unbolting the header taking everything from the header back off
Old Aug 5, 2002 | 05:44 AM
1990hondaHF's Avatar
From what I understand...to make low end torque you NEED backpressure! No back pressure = no low end power....BUT what you gain is high end horsepower. I experienced this with my V6 Ford Contour. I got rid of the main cat and bolted on a SVT Duel exhaust. High end HP went through the roof but low end torque was nowhere to be found. I also LOST about 5 MPG with that combo.
by the way JCWhitney.com has the same item...24JE1628R....$19.99+shipping.
Old Aug 5, 2002 | 07:22 AM
civicmark's Avatar
Default Re: open headers... (1990hondaHF)
[QUOTE]From what I understand...to make low end torque you NEED backpressure! No back pressure = no low end powerQUOTE]
unless you're FI
Old Aug 5, 2002 | 10:05 AM
d-wreck's Avatar
hondahf has it wrong, this a domestic's tale on how to make hps in the 80s.
you will notice a difference maybe drop as much a 3 tenths or more
derek
Old Aug 5, 2002 | 12:17 PM
Mugen Dom's Avatar
Default Re: open headers... (d-wreck)
ok heres the deal ill looked threw al my scc mags and found the issue and here are the #s on a first gen b16
with apexi WS exhaust,aem cai,powercore cat, edlebrock header 421... 151 HP and 107 lbs of toque.
with no exhuast they hit 155 HP and 112 ft lbs of torque.
real #s from a dyno
Old Aug 5, 2002 | 12:25 PM
CRXtraMoney's Avatar
Dyno's can lie. Check and look at what rpm those numbers come from. The large numbers are found near red line.
FredoTheChimp's Avatar
yep, loss of back pressure doesn't cause loss of torque, you don't want back pressure, but you want to maintain velocity, which creates optimal gains on hp and torque scales, yeah check out the SCC B16 Civic Project car, they ran no exhaust and saw gains, you might also want to look through previous issues in the "Performance Dictionary" page they had a previous article on exhausts.
Old Aug 5, 2002 | 12:40 PM
.nate's Avatar
Default Re: open headers... (Accord92sir)
I have run both. And you loose MAD bottom end running open header, but gain some serious top end... With the open headers the car is a snail untill I hit 6k-8k then it screams.
Old Aug 5, 2002 | 12:41 PM
Mugen Dom's Avatar
Default Re: open headers... (CRXtraMoney)
taht is corect peak power at 7500i have teh dyno chart here if u have any questions from 2k they had like 80 lbs of torque and at 4500 it starts to go up at 5k torue is at 105 and peaks at 5500 at 7k it drops off but hp is still rising at 7 k till 7500 it starts to drop
Old Aug 5, 2002 | 12:57 PM
Urban Business
Guest
Posts: n/a
thank you
when i ran an open header on my d15 is sounded great (loud as **** tho) and had MORE hp and trq. lost no low end at all. now im header back no cat, quieter and slightly slower. backpressure is BAD BAD BAD BAD BAD in ANY case. proper flow is GOOD GOOD GOOD
Old Aug 5, 2002 | 01:42 PM
slowpokesi's Avatar
Default Re: open headers... (TorteX)
the owner of this crx before me replaced the stock muffler with a midas special, it has one tip, and honestly my dick has more circumfrence then the pipe coming off the muffler, my car with the b16 was super slow. currently what im doing is running the car with the rear section unbolted, i have kept the muffler hanging to fool the popos, but its not connected, i have seen a big diffrence in power on the highway and on the track, i think it might feel a lil bit slower if im just doing regular driving, but if i mash the gas then its all good again.
someone buy me an exhaust system so i dont get a ticket :D
[Modified by slowpokesi, 10:43 PM 8/5/2002]
Old Aug 5, 2002 | 09:15 PM
91HATCH's Avatar
overall...does open headers help 1/4 mile time for a b16?
Old Aug 5, 2002 | 09:20 PM
Mugen Dom's Avatar
yeh for sure
Old Aug 5, 2002 | 10:32 PM
raene's Avatar
They weren't running 'no exhaust' they were running a JG Edelbrock Race Header, which is a header with a small dump tube coming off the end - check the pics.
You'll definitely run faster open header, but it's loud - ear-bleeding loud. Remember that sound clip I posted with my car running basically open header? Here it is again: Crappy sound quality
notsoslow
Aug 18, 2009 05:52 AM
MN_BB4_Si
Jun 22, 2005 06:36 PM
eg4usdm
12
Mar 13, 2005 01:21 PM
91 POS
Apr 29, 2003 09:46 AM
SI HB 90
Mar 3, 2002 07:22 PM
