low gas mileage on 02 accord ex. why?
Old Dec 26, 2008 | 06:22 PM
howard-zhang's Avatar
Post low gas mileage on 02 accord ex. why?
I have 02 accord ex 4 doors, 70K and using mobile one engine oil for honda, with the mobile filter as well, but the gas mileage is about 18 mile in town, and highway is about 27 in town. i check the tire pressure is 32 psi on four of wheels. May I get some idea about the problem of this car?
Old Dec 26, 2008 | 07:19 PM
FunnyVictor86's Avatar
Default Re: low gas mileage on 02 accord ex. why?
i dont know what mpg f23 6th gens are suppose to get ... when is the last time you replaced your o2 sensor? when was the last full maintenance: plugs, wires, cap/rotor ect ... and the way you drive obviously makes a difference as well
Old Dec 26, 2008 | 09:12 PM
P_Adams's Avatar
Are most of your trips 6 miles or less?
Kansas can get pretty cold this time of the year and you could be running with the engine never really warming up.
Check your tire pressures
Research when the last time tune maintaince was performed
And think about having the primary O2 sensor changed out. Although only 70K, the 6 years it took to get there could be problamatic. 11K/year is very low milage/use and the O2 sensor could have issues. When they get lazy, they can't react fast enough for changing engine conditions and you start loosing milage and performance (it's all about 'counts')
P
Old Dec 27, 2008 | 01:09 AM
YeuEmMaiMai's Avatar
V6?
if so it's about normal unless you are easy on the throttle
Old Dec 27, 2008 | 04:46 PM
Importn2oRacer's Avatar
Yea that sounds about right for a V6. I-4 probably not.
Old Dec 29, 2008 | 05:47 PM
it's four cylinder only
Old Dec 29, 2008 | 06:30 PM
hon2984's Avatar
is there a check engine light on?
Old Dec 29, 2008 | 08:10 PM
it's not on....
Old Dec 29, 2008 | 08:32 PM
are your rpms correct if it is an auto? do you get good heat from the engine?
Old Dec 31, 2008 | 06:36 AM
i think so, it is normal
Old Dec 31, 2008 | 06:55 PM
gasha1's Avatar
although you don't have a check engine light on I recommend you check your EGR. I just had mine fix and my MPG is much better.
Old Jan 1, 2009 | 07:24 PM
sorry, what is EGR?
Old Jan 1, 2009 | 07:49 PM
P_Adams's Avatar
sorry, what is EGR?
EGR
Exhaust Gas Recirculation valve
Looks Like This:
Hope this helps
P
syclone0
19
Mar 27, 2012 11:32 PM
djcrunkmix
Sep 5, 2011 09:42 PM
A Tribe Called Honda
Oct 2, 2008 05:40 PM
ceddyced
Dec 29, 2005 09:07 AM
KDoGx504
Sep 29, 2005 03:30 PM
