cant get rid of code 9
any ideas? im thinking i cleared the ecu out, i pulled the hazard fuse and the pulled the neg terminal off battery. i have tried 2 different working dizzys.
the car runs fine, even though i havent been on the road with it cause of a broken throttle cable. but i can give it gas at the tb and it revs out great.It dont have a miss in it. after abou 10 min of ideling it runs like crap wont take gas or anything and sounds like its camed out
On a side note i cant belive how much better it seams to run on obd1 lol
car is a 91 hatch dx, mpfi swap obd1 swap << done on seperate ocasions
mini me z6 head y8 gear,b7 bottom
running a p05 ecu, and no IAT sensor,, and my 4 wire isnt hooked up yet
You dont NEED the o2 sensor. Nor will it effect idle. After it warms up it runs like crap? Check the timing. You might have it 1 or 2 tooths off. The p05 ecu is out of what? I forget. Do you have the jumper harness to obd1?
znjdevils07
Apr 29, 2011 02:19 PM
yoshi06
Mar 27, 2009 07:32 PM
