'97 CX supension in an Si?
Old Aug 4, 2002 | 03:57 PM
Stop the Beast's Avatar
Default '97 CX supension in an Si?
Will '97 Civic CX struts and coil-overs bolt into an 90-91 Civic Si?
Old Aug 4, 2002 | 04:03 PM
JaiDM's Avatar
Default Re: '97 CX supension in an Si? (brokstar)
i know the front will... not 100% sure about the rear.
Old Aug 4, 2002 | 04:32 PM
Default Re: '97 CX supension in an Si? (JaiDM)
Have you seen it done it the front before?
Old Aug 5, 2002 | 06:53 AM
Ham'ed Hatch
Guest
Posts: n/a
the fronts will bolt in as long as you use your '97 damper forks.
the rears will bolt right in.
Old Aug 5, 2002 | 02:54 PM
Default Re: '97 CX supension in an Si? (two.oh)
Is a Damper fork the deal that actually looks like a fork and hold the bottom of the strut to the hub?
Old Aug 5, 2002 | 02:55 PM
Ooh ooh another, The Skunk2 coil over will work with the '90-'91 stock supsension right?
Old Aug 5, 2002 | 03:02 PM
wuhungsixxx's Avatar
New User
they will bolt in most likely...but your front end will be higher than you rear...the front suspension forks are longer than the older EF ones
Edit: you can get a coil or a sleeve-adj. coil like skunk2 and GC to fit on about any car/shock...
i have my GCs from my old accord on my 95 gsr
[Modified by wuhungsixxx, 4:07 PM 8/5/2002]
Old Aug 5, 2002 | 07:27 PM
Default Re: '97 CX supension in an Si? (wuhungsixxx)
So my best bet is to use the Skunk2 Coil-overs I have in my EK use the rear shocks I have in my EK and buy a new set of front shocks for the EF. Thanks.
Old Aug 6, 2002 | 06:25 AM
Ham'ed Hatch
Guest
Posts: n/a
to the lower control arm, but yes.
not necessarily. the reason you'd have to use the EK damper forks, is because the 88-91 struts were skinnier than all 92-up civics. your fronts would work fine.
are you selling your suspension or buying an EF?
Old Aug 6, 2002 | 07:39 PM
I'm kinda of in limbo right now just thinking of what to do...
doug118
Suspension & Brakes
Aug 29, 2009 12:24 PM
ChiLS
Aug 25, 2008 03:28 PM
speedy_beedee
May 2, 2007 06:15 PM
turbo*s2k
13
Jan 24, 2004 09:39 AM
Racing rice
Nov 5, 2001 11:14 AM
