oil leaking into spark plug wells....any fixes?
Old Aug 4, 2002 | 02:47 PM
mailforjon's Avatar
Default oil leaking into spark plug wells....any fixes?
i have a 4th gen ex and i recently swapped out my bosch platinum 4's for some NGK plugs and noticed that there was quite a bit of oil on the plugs (on the electrodes AND in the plug tube). i replaced the valve cover gasket and the plug seals but i was wondering if there could be any other cause of this poor oil control in the crankcase. perhaps a blown head gasket? <gasp> also, will oil on the electrodes ruin the plug wires also?
thanks for any input.
-jon-
Old Aug 4, 2002 | 02:48 PM
mailforjon's Avatar
Default Re: oil leaking into spark plug wells....any fixes? (mailforjon)
it appears that i used ''also'' twice in one sentence. austin powers much?
''allow myself to introduce.........myself''
Old Aug 4, 2002 | 04:09 PM
H23 Power's Avatar
valve seals
Old Aug 4, 2002 | 04:56 PM
Kazmans94cord's Avatar
Default Re: oil leaking into spark plug wells....any fixes? (Ti1301)
duct tape and super glue
Old Aug 4, 2002 | 05:28 PM
Brandon's Avatar
Life is Suffering
Default Re: oil leaking into spark plug wells....any fixes? (kazmans94cord)
lol....The world's greatest fixes.
Old Aug 4, 2002 | 06:01 PM
KTeller8's Avatar
Default Re: oil leaking into spark plug wells....any fixes? (accordvtec)
its like a gift from god the closer you get to Alabama .. i see it when they come over to my side of FL
Old Aug 4, 2002 | 11:00 PM
b18bEG's Avatar
chew up some bubbulicios, or somthin', it'll plug that **** up all good.....
Old Aug 5, 2002 | 09:30 AM
briq4's Avatar
Default Re: oil leaking into spark plug wells....any fixes? (h22akrd)
The spark plug oil seals are bad, they aren't hard to replace and are really cheap. My Dealer did it while they were doing a valve adjustment. And the only reason the electrode was coverd in oil is that when you unscrewed the plug the oil ran down onto it. The leak is above the threads. Not sure if it would mess up the wires tho.
Old Aug 5, 2002 | 09:41 AM
smokin rubber's Avatar
Default Re: oil leaking into spark plug wells....any fixes? (briq4)
well my plug seags were replaced less than 10k ago and there is oil in the #2 and #3 plugs, but only on the "nut" part of the plug. any ideas
Old Aug 5, 2002 | 10:52 AM
Ideal's Avatar
Default Re: oil leaking into spark plug wells....any fixes? (01GSR)
valve seals
Old Aug 5, 2002 | 02:36 PM
bill-71SS's Avatar
Default Re: oil leaking into spark plug wells....any fixes? (Ideal)
replace the valve cover and the 4 seals on the spark plug tubes/
Old Aug 5, 2002 | 04:34 PM
CardDealer's Avatar
Banned
Default Re: oil leaking into spark plug wells....any fixes? (bill-71SS)
Modified by CardDealer at 4:24 PM 11/17/2006
qhiggy
10
Mar 3, 2015 08:49 PM
VTEC_Du_Ma_Mai
Sep 6, 2008 11:08 AM
VTEC_Du_Ma_Mai
Sep 5, 2008 01:41 PM
premo_si
Jan 23, 2008 08:57 PM
luciffer
Mar 18, 2005 07:43 AM
