anyone have pics of neon radiator on a crx?
Old Aug 4, 2002 | 11:43 AM
uneekcrx's Avatar
Default anyone have pics of neon radiator on a crx?
topic says it all....i saw one pic but it wasn't very clear
Old Aug 4, 2002 | 11:47 AM
slowman's Avatar
I took way too long
Default Re: anyone have pics of neon radiator on a crx? (uneekcrx)
i hope no one wasted their money on one.
Old Aug 4, 2002 | 12:12 PM
uneekcrx's Avatar
Default Re: anyone have pics of neon radiator on a crx? (90SIvic)
why.....it's half the size of the stock radiator and if you're running a turbo you can use all the room you can get
Old Aug 4, 2002 | 12:25 PM
slowman's Avatar
I took way too long
i thought you meant one with some neon lights on it, not the car.
Old Aug 4, 2002 | 12:40 PM
DOHCtorJT's Avatar
you mean dodge neon radiator?
Old Aug 4, 2002 | 12:45 PM
uneekcrx's Avatar
Default Re: anyone have pics of neon radiator on a crx? (DOHCtorJT)
yup
Old Aug 4, 2002 | 01:01 PM
slowpokesi's Avatar
Old Aug 4, 2002 | 04:17 PM
kyler's Avatar
sorry I had to
seriously though I know its been done by fabbing brackets and extending hoses so if you're up for a bit of work it should be no big deal...
Just curious but why dont you just use a del sol rad? got a hookup on a neon one?
Old Aug 4, 2002 | 05:09 PM
uneekcrx's Avatar
Default Re: anyone have pics of neon radiator on a crx? (kyler)
the del sol radiator is too tall...the dodge neon radiator is suppossed to be a direct fit in the 88-91 civic/crx using the stock pass. side mounting spot
Old Aug 4, 2002 | 05:12 PM
blacksoul's Avatar
I read that you can use 2 of the stock mounts.
Old Aug 4, 2002 | 05:13 PM
uneekcrx's Avatar
Default Re: anyone have pics of neon radiator on a crx? (blacksoul)
right that's what i meant....
Old Aug 4, 2002 | 06:10 PM
DOHCtorJT's Avatar
Keep in mind there are 3 different Neon radiators.
There's the small one, similar to a newer civic, which was found on 95 base models with no AC and a manual tranny.
Then there's the standard double wide one found on most neons.
There's also another from any mexico build neons that is the same design as the standard one, but thicker. To tell a mexi-built neon, the first letter of the VIN will be 3. 98-99 Neon R/Ts do not have this radiator, regardless of where they are built.
The 2000-2003 Neon radiators are different from the 95-99 and probably won't work.
Hope that helps, if you need measurements, let me know
Old Aug 4, 2002 | 06:33 PM
uneekcrx's Avatar
yea i read that i need to get one from a 99 and older neon w/o ac
Old Aug 4, 2002 | 07:54 PM
wickedxboi's Avatar
does anyone actually know what year and model is will fit into a crx?
Old Aug 4, 2002 | 11:38 PM
Redline130's Avatar
Default Re: anyone have pics of neon radiator on a crx? (wickedxboi)
this might help https://honda-tech.com/zerothread?id=181371
JWhonda_ride
Sep 22, 2008 01:56 PM
1990hondaHF
Aug 20, 2007 11:44 AM
ham
May 18, 2006 01:46 PM
BoostedCivicEJ8
Jul 2, 2005 07:21 AM
