i wanna replace my fluid filled mount
Old Dec 23, 2008 | 12:57 PM
VtecFreePrelude's Avatar
Default i wanna replace my fluid filled mount
well i think most people will understand what im loking for but just in case...
i would like to get rid of the fluid filled motor mount(driver side) and cant seem to find anyone that sells one. i dont need a set unless thats the only way i can.
has anyone found a decent way to accomplish this?
Old Dec 23, 2008 | 01:55 PM
Acidcrakker's Avatar
Default Re: i wanna replace my fluid filled mount
What is a fluid filled mount?
Old Dec 23, 2008 | 02:09 PM
tortuga89's Avatar
what year is your prelude
Old Dec 23, 2008 | 02:12 PM
Jas9848's Avatar
i think maybe hasport or innovative makes a kit.
Old Dec 23, 2008 | 07:21 PM
sorry i forgot i dont have a sig pic. its a 93 SI with a h22 swap.
Old Dec 23, 2008 | 07:39 PM
ethereal2pt2's Avatar
fluid? i swore it was rubber..
Old Dec 23, 2008 | 07:48 PM
Thats what I thought too!
OP if your talking about rubber mounts, I have a brand new set for you than.
You can replace all your old and crusty ones at half the cost of what Honda would charge you.
Old Dec 23, 2008 | 08:08 PM
Kronn 98SH's Avatar
is this process similar to replacing blinker fluid?
Old Dec 23, 2008 | 08:10 PM
neither of the above companies show anything about what i am looking for online. so if anyone knows how to help pm me
or if anyone can get ahold of the oaks to see what they did that would be great
Old Dec 23, 2008 | 09:05 PM
go get some ES inserts
Old Dec 23, 2008 | 09:13 PM
InvaderTrax's Avatar
Looks like they quit making them. Anyway, the 4th gen driver side mount is not solid rubber, it's filled with oil. It's very good at dampening vibration, but not particularly stiff. They also make a mess when the bust open
Old Dec 23, 2008 | 10:07 PM
jlude90's Avatar
yeah, when i worked at honda i'd cut the warrenty ones open and shoot the oil everywhere, it was awesome
if you get an aftermarket set they'll all work, so long as they're for a 4th gen with an F/H engine
Old Dec 24, 2008 | 06:51 AM
energy suspension inserts are retarded. i had a set and they didnt fit. im not gonna mess with that **** again.
invader- good to see someone else actually knows about some of the finer points of their own car.
still trying to find a rubber driver side. i can live with the other ones baing rubber cause ill just fill them with polyurethane and itll be just as good. all i need is a driver side and ill be fine
Old Dec 24, 2008 | 06:55 AM
What do you even need those mounts for. The OEM ones are more than sufficent. How much vibration could you possibly be suffering from.
Ive read about these mounts, I dont ever recall coming across a set of them for honda.
Old Dec 24, 2008 | 07:28 AM
Giant_Bean's Avatar
the OEM honda drivers side mount is a hydraulic(fluid filled) mount. He is trying to find a solid replacement for it.
Old Dec 24, 2008 | 08:26 AM
Oh well than that would make sense. He can try ESP.com
http://www.explicitspeedperformance.net/
I just picked up a set of those mounts myself.
Old Dec 24, 2008 | 09:40 AM
h23prelude's Avatar
you could drill a small hole in the fluid mount and fill it with a solid drying vulcanizing rubber/silicone sealant materal, let it dry for a whole dry and then its basically a solid rubber mount.
this is just an idea, ive never tried it so its just food for thought...
Old Dec 24, 2008 | 10:42 AM
jlude90's Avatar
i was looking through the catalogue last night and it doesn't look like any of the 4th gens had a normal drivers side mount
just get the innovatives and you'll be good to go
Hadn't thought about that. It would have to be cleaned out really well before though. It's filled with oil so the filler wouldn't be able to bond if any was still in there
prodjay10
Honda Civic (2001 - 2005)
Jul 13, 2017 09:20 PM
96 Accord EX
Sep 27, 2014 04:11 PM
pwd
Jun 19, 2014 05:15 AM
Alibi86
Aug 23, 2005 10:33 PM
onelowchef
Jan 10, 2005 09:14 AM
