IAT sensor
I just purchased a sohc f22b. When i went to go hook up the harness, the IAC sensor is in the back of the intake manifold. The old motor the IAC sensor in on the right side of the intake manifold. They are 2 different sensors( the old motor the sensor is held in by 2 screws, and the new f22b is just in the back of the intake manifold) Where can i find the replacment IAC sensor for the JDM f22b?
IAC as in idle air control or IAT as in intake air temp?
IAT....
http://www.hondaautomotiveparts.com/...NTAKE+MANIFOLD
Go to that and scroll down in the list to INTAKE MANIFOLD then its #26 $11.48... Its #28 in the picture but listed as 26.
IAT....
IAT....
IAT....
What year F22 are you refering to? Both the 94 F22B1 and the 96 F22B2 intake manifolds that I have had in my hands had the screw in type IAT sensor.
Here is the pic of the 94 F22B1 before I cut it up for my ITBs, as you can see it has the screw in type IAT on the rear of the IM.
and here is a pic of the 96 F22B2 intake manifold with the runners removed.
The Honda Air Temperature Sensor Assembly (aka IAT) part number for the 94-97 USDM F22B1 & 2s is 37880-P0A-A02. No change in part number for any of the I4 5th gens.
Your welcome!
Your welcome!
Your welcome!
Your welcome!
