Shift light stays on???
Old Aug 4, 2002 | 10:55 AM
speedymon's Avatar
Default Shift light stays on???
I installed my shift light but it stays on. I've got the ground to the chassis. Green wire to the test tach wire. And i've attached the red to ign1. It stayed on so i switched it to ign2, but no luck. Any ideas?
Old Aug 4, 2002 | 11:38 AM
CRXSiR500's Avatar
Default Re: Shift light stays on??? (speedymon)
an aftermarket tach? I don't know which tach you got, but a lot of times they have a **** on them that you can turn to set it. try pushing the **** (if you have one) then turning it.
Old Aug 4, 2002 | 11:41 AM
VTECorona's Avatar
Default Re: Shift light stays on??? (CRXSiR500)
You may have the wrong RPM wire hooked up and its getting a constant misreading. Check your wiring...
tyler100
11
Dec 26, 2007 06:33 PM
Hatch It
Nov 19, 2004 07:50 PM
ShakesTheKlown
Jun 15, 2004 06:59 PM
SiZ
Apr 11, 2003 02:32 PM
