help my oil burst out
i have a 95 accord all my oil burst out from my oil filter i recently did an oil change the car was running good last night n today in the morning while driving everything was coming out all my oil is gone n idk what can it be i change the oil filter n it still did the same thing!
thanks
thanks
Can you tell were the oil leaked out, take the filter off the car and check to see if the filter is cracked. or if it was leaking from the gasket area.
Did you make sure to remove the old rubber o-ring before you put on the new filter & o-ring?
What type of oil filter did you use?
if leaking from the filter check for a double gasket it happens on aftermarket ones where the old gasket sticks to the housing and the new one on the filter doesn't seat right..
thanks
thanks
Good luck (and Happy Holidays)
p
vtech_tuner
Aug 7, 2005 09:37 PM
