Smelling Gas Fumes
Old Dec 21, 2008 | 08:05 PM
scottmog's Avatar
Default Smelling Gas Fumes
And not from my rear end.
Whenever i get out of the car when parking in the garage i smell gas fumes. Maybe this is one of the reasons i am getting 25mpg from a sohc zc swap? >< where should i check on my fuel lines?
ps: i am not smelling gas inside my cab, only outside.
Old Dec 21, 2008 | 09:04 PM
acmoc's Avatar
Default Re: Smelling Gas Fumes
carb?
It could be running rich
Old Dec 21, 2008 | 09:26 PM
scottmog's Avatar
Originally Posted by acmoc
carb?
carburator? naw fuel injected
Ive heard this many times before "It could be running rich" what does that mean?
Old Dec 22, 2008 | 09:13 AM
scottmog's Avatar
Bump
Looking for a lil more help
Old Dec 22, 2008 | 09:44 AM
digitally_remastered's Avatar
if you smell gas you definitely have a fuel leak or open tank(water residing on top the tank will do that to it over so long). i wouldnt drive the car with the smell of the gas aroma lingering like you describe it.
Old Dec 22, 2008 | 10:08 AM
acmoc's Avatar
Oh, my bad, it said cab not carb, running rich could mean your pouring too much fuel into your cylinder and not all of it is burning.
Check your fuel lines for leaks, and check all your vaccumm lines too, also check your gas tank, some peoples have leaks where you pour the gas in.
Is your gas cap good?
Old Dec 22, 2008 | 03:44 PM
schock3's Avatar
o2 sensor?
Old Dec 22, 2008 | 04:45 PM
~sp33~'s Avatar
EFB055
Any codes? Check your ignition timing. If it's off it could be causing it to smell rich.
Old Dec 22, 2008 | 06:11 PM
Tyson's Avatar
look around your injectors on the intake manifold. check if its dirty, like a lot of sludge. your injectors are leaking if thats the case. double check by taking some brake cleaner and cleaning the manifold surface off completely. then recheck a few days later.
btw, does it take long for you to start your car in the mornings?
Old Dec 22, 2008 | 06:51 PM
Gomba's Avatar
Sounds like it's running to rich.
Old Dec 22, 2008 | 09:19 PM
jb2wheels's Avatar
Sometimes, a new gas cap with a fresh gasket will cure gas fume issues.
Old Dec 22, 2008 | 09:43 PM
Tyson's Avatar
wait, is this car on or off?
Old Dec 23, 2008 | 04:11 AM
~sp33~'s Avatar
EFB055
...Coming from the front of the car?
Old Dec 23, 2008 | 09:50 AM
scottmog's Avatar
lol dang so many replies. ima go outside look at everything then reply again thx so much!
Old Dec 23, 2008 | 01:05 PM
rangerxtrn's Avatar
This happened to me one day at a Shell Gas Station... check your fuel rail and components, and check to see that the fuel line hasn't rubbed chafed inside the engine compartment... that's the best I got for that problem... and don't overfill your gastank... that could be a number of things though, cracked fuel line, leaky fuel filter, do you have the right FPR for your swap?, etc. that is just going to take some time to track down, is it puddling up fluids on the floor?
Old Jan 1, 2009 | 11:48 AM
joshsayswhatt's Avatar
on this note i need a new gas cap, do they have universal caps or do i need a cap that only fits civics. i have a 94 civic dx
Old Jan 1, 2009 | 11:49 AM
i need help on this quick since i need to drive the car tommoro and i do not have a cap
domrw
Honda Civic (2001 - 2005)
10
Mar 2, 2017 06:40 AM
TealCivic93
Apr 8, 2006 09:31 AM
Steve90HB
Apr 4, 2004 11:08 AM
kim_2_da_chee
Feb 5, 2003 09:44 AM
beakert216
Aug 8, 2002 08:08 AM
