Cast weld question
Old Dec 21, 2008 | 05:58 PM
Dkahn18's Avatar
Default Cast weld question
I just bought an ls b18a1 block,it has a small hole near where the timing cover bolts on, i was wondering if it would be ok to weld it since theres really no pressure going thru there?
Old Dec 21, 2008 | 06:13 PM
turkeyslow's Avatar
Default Re: Cast weld question
It is okay to weld although I recommend taking it to a professional. Information varies some say it's better to braze a engine block some say it's better to weld, I recommend asking your local machine shop.
Old Dec 21, 2008 | 06:28 PM
Dkahn18's Avatar
i guess what im asking is , is it fixable.
Old Dec 21, 2008 | 07:38 PM
Longitudinal's Avatar
Definitely fixable. Cast welding is a little tricky, but it's not spells and incantations. Do it yourself if you have cast iron experience or take it to a welding shop. Thing with cast is pre- and post-heating. Even heat distribution is critical. Iron can shatter if heated or cooled improperly, and will crack eventually if heat during and after the welding process is not managed properly.
Old Dec 21, 2008 | 08:09 PM
downest's Avatar
Must be the first cast-iron B18.
Old Dec 21, 2008 | 09:00 PM
-RedneckDave-'s Avatar
Working
I am sure he meant cast aluminum.
Old Dec 21, 2008 | 09:44 PM
downest's Avatar
I know, seemed like everyone else was talking about cast iron though.
Old Dec 21, 2008 | 11:40 PM
SD_Lurker's Avatar
HT White Ops
No, I think its the fact that you had no idea b-series blocks, all honda blocks for that matter, are cast aluminum. Its ok you can admit it because no where does it SEEM like they are implying cast iron.
Old Dec 22, 2008 | 02:26 AM
Dkahn18's Avatar
So it will be ok , even though its cast alluminum i can still make this motor purr again.
Old Dec 22, 2008 | 03:38 AM
downest's Avatar
Originally Posted by sd_lurker
no, i think its the fact that you had no idea b-series blocks, all honda blocks for that matter, are cast aluminum. Its ok you can admit it because no where does it seem like they are implying cast iron.
lol.
Old Dec 23, 2008 | 05:10 PM
Engloid's Avatar
OG Fabricator
It can be fixed. Cast aluminum usually isn't as bad to crack when welded as cast steels are. Also, cast metals are much better than they used to be.
If it were me, I'd grind the crack out to be a groove about 1/8" deep, and TIG it up in one pass. ...no preheat or postheat.
Old Dec 23, 2008 | 06:36 PM
SD_Lurker's Avatar
HT White Ops
Ya but people aren't as good as you!
Old Dec 24, 2008 | 06:42 AM
carchitect's Avatar
Originally Posted by SD_Lurker
..... all honda blocks for that matter, are cast aluminum....
What about the 89 and older accords, 87 and older preludes, and 83 and older Civics. They are all cast Iron blocks. There are also plenty of motorcycles that use cast iron blocks.
KtHaNxBai
May 25, 2012 07:32 AM
tepid1
Paint and Body
Apr 9, 2010 02:15 AM
doug118
Welding / Fabrication
19
Feb 25, 2009 06:24 AM
Dkahn18
Dec 21, 2008 08:10 PM
BB6-213
10
Dec 12, 2006 11:55 AM
